Page 1 of 3 1 2 3
Oil pressure blowing out filter gaskets?! #698441 02/19/06 11:47 PM
P
poncho Offline OP
Anyboby know what would cause the oil to blowout the oil filter gaskets I overhauled a 20R and we have blown out three oil filter gaskets is there a pressure release valve that is sticking? Or does it need to be adjusted? I am clueless at this point so help would be greatly appreciated.
Re: Oil pressure blowing out filter gaskets?! [Re: poncho] #698442 02/20/06 12:19 AM
4Crawler Offline
What type of filters? As I understand it, the Toyota oil filters have the pressure relief/bypass valve inside the filter:
- http://yarchive.net/car/oil_filters.html
That could cause problems if running a filter designed for a domestic vehicle which may have the bypass valve external to the filter.
Re: Oil pressure blowing out filter gaskets?! [Re: 4Crawler] #698443 02/20/06 12:25 AM
P
poncho Offline OP
Fram PH-16
Re: Oil pressure blowing out filter gaskets?! [Re: 4Crawler] #698444 02/20/06 12:32 AM
P
poncho Offline OP
so are you saying that I should get a filter from Toyota for that? because the time the engine ran with a champion filter and ran alright. I tried a purolator and it blew out and two Frams
Re: Oil pressure blowing out filter gaskets?! [Re: poncho] #698445 02/20/06 12:40 AM
4Crawler Offline
I generally run Purolator filter speced for the 22R on my '85. But if the filter is speced for use on Toyota, it should have the internal bypass valve, I think they open around 22psi. Might be some other issues, though.
Re: Oil pressure blowing out filter gaskets?! [Re: poncho] #698446 02/20/06 12:47 AM
Chucky MoMo <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Oil pressure blowing out filter gaskets?! #698447 02/20/06 01:10 AM
P
poncho Offline OP
so is there a adjustment certain pressure specifications for adjustments etc?
Re: Oil pressure blowing out filter gaskets?! [Re: poncho] #698448 02/20/06 02:30 AM
Not on the stock oil relief valve.
There's a spring and plunger under that cap.
All you can do is check to make sure that the plunger isn't stuck/seized.
I did see on a post over at the pirate4x4 forum about an adjustable relief cap that allows you to raise the oil pressure, I don't know if it will let you lower it though.
Re: Oil pressure blowing out filter gaskets?! #698449 02/20/06 03:17 PM
P
poncho Offline OP
thanks Chucky will do
Re: Oil pressure blowing out filter gaskets?! [Re: poncho] #698450 02/25/06 01:36 AM
P
poncho Offline OP
well.........it is not the plunger <img src="/forums/images/graemlins/confused.gif" alt="" /> and right now we are not sure what thell it is. we installed a oil gauge to see how high it would go we used another stock spring in place of the one that is there and it went well over 50+ PSI. any other ideas? we are open for suggestions.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 1.847s Queries: 16 (0.004s) Memory: 0.6357 MB (Peak: 0.7569 MB) Data Comp: Off Server Time: 2026-06-22 05:09:36 UTC
