Got no results in "search" so what engine will directly interchange with a.. #699202 02/21/06 07:34 PM
1
1sttrooperII Offline OP
2.8 on a 91 trooper with automatic.
Thank you.
Re: Got no results in "search" so what engine will directly interchange with a.. [Re: 1sttrooperII] #699203 02/21/06 07:42 PM
Bigpoppax2 Offline
Chevy 3.4 will sawp with minor changes. The starter will need to be relocated to the opposite side. Search for 3.4
Joe
Re: Got no results in "search" so what engine will directly interchange with a.. [Re: 1sttrooperII] #699204 02/22/06 02:26 AM
Ed Mc Offline
A Rodeo or P'up 3.1 (4WD only) is a direct bolt-in replacement. And likely the 3.1 with cast-iron heads and distributor, found in early 90's GM FWD minivans, is a direct bolt-in also.
I imagine a Camaro 3.1 might bolt in if you drilled starter holes but hardly any point there, you might as well rebuild an Isuzu 2.8 and use 3.1 crank & pistons to accomplish the same thing without drilling.
Also, later models of the Fiero 2.8 V6 are a direct drop-in since they already have the starter mount on the correct side.
A 3.4 is your bet bet for Cost vs. Performance.
HTH..........ed
'90 Troop 3.4 LS
'89 Troop RS (Has Valve Issues, needs Counseling)
HI, I'm Ed and I'm a Trooper-holic!
Keep On Troopin'......
PHP: 7.4.33 Page Time: 1.177s Queries: 15 (0.003s) Memory: 0.5932 MB (Peak: 0.6462 MB) Data Comp: Off Server Time: 2026-05-28 14:43:09 UTC
