Somebody Please help!!! #699363 02/22/06 02:46 AM
Ok here is the deal, I am a good backyard mechanic but I am in need of some technical help, this is my situation. I am up here in the NW, right now it is cold in the mornings when I leave for work. Truck starts up just fine, but idles real low, 800. By the time I get to work the engine is all warmed but the idle is now sitting between 1400-1500, I just recently replaced the carb with a prof. rebuilt one, everything went together fine, all vacuum lines are ran (according to the vacuum diagram), so I am kind of lost on why the carb is acting this way? Gas milage is down a bit too.
OK here is one more thing I just remembered! while the truck is running, when ever I tap the break pedal, my running lights come on, anyone know where to start looking for the short? I am assuming that is what is causing it?
Thanks again. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Somebody Please help!!! #699364 02/22/06 03:48 AM
87Toy4x4 Offline
whenever you start the truck cold fully depress the gas pedal once or twice to engage the fast idle and choke. it also gives it a richer mixture which is good for the engine when its cold. after that it should idle at 1500 rpms or more until warm. if your truck is warm and it still idles up high you can usually stomp the gas for a second to get it back down to the normal 750-900 rpms.
Re: Somebody Please help!!! #699365 02/22/06 07:20 AM
4WD22R Offline
This is kinda a dumb one but check the throttle linkage on the carb, mine sitcks for some reason and every now and then I have to give the throttle a little 'blip' to unstick it.
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: Somebody Please help!!! #699366 02/22/06 03:27 PM
jx94148 Offline
The brake/running light thing sounds like a short between the brake light wires and the running light circuit. Start at the tail light sockets and work your way forward along the brake light wires. If you have wiring for a trailer, its probably part of the problem.
'87 4Runner. '83 Honda XL250R. No mods on either.
PHP: 7.4.33 Page Time: 0.007s Queries: 14 (0.005s) Memory: 0.5961 MB (Peak: 0.6548 MB) Data Comp: Off Server Time: 2026-06-24 13:00:54 UTC
