Stupid ??????? ATF fill 2nd Gen
#699938
02/23/06 08:35 PM
OK Guys! I know, I know! Stupid question! I've had this 2000 Trooper with automatic Tran, 3.5 V6 since it was new. I've never been able to find the transmission dipstick. I've been through the owners manual several times. Either I'm blind or it's not in there.
WHERE IS IT? Not the manual, the dipstick, Dipstick!
Bob
OK, so there isn't a dipstick! Just a filler hole with a plug in it?
Bob
Re: Stupid ??????? ATF fill 2nd Gen
[Re: Pilotbob]
#699939
02/23/06 09:23 PM
OK, so there isn't a dipstick! Just a filler hole with a plug in it? Yep you got it.
[Re: Pilotbob]
#699940
02/23/06 09:24 PM
Yep, that is one of those irritating Isuzu things, you almost have to have the trooper on a lift with it running, pull the upper plug which is about an inch or so higher than the drain plug and off to one side of the pan. it still faces down so if you have to add fluid you have to have a hose with a hook on it. I go to a trany shop near by and let them service mine once a year and then not worry about the mess, and these light duty A/Ts need extra care anyway.
Reid
Reid 96 Trooper, 94 Amigo, 89 swb RS trooper
[Re: Socalboke]
#699941
02/23/06 10:33 PM
Hey bob just do what I do. Go to homedepot and buy yourself a garder tank sprayer (with a pump to pressurize). The nozzle already has the perfect angle to snake it in. All you have to do is pressurize the tank and then squeeze the trigger. You might still spill a little, but it's better than using a suction pump with all its tubbing. HTH <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Mando 1998 Rodeo S 4x4 3.2, OME 913's, 2" coil spacers, Rancho 9000's
[Re: txsoulfly]
#699942
02/23/06 10:50 PM
So, doesn't it kind of P___ you off because we don't have a dipstick?
I've put 165,000 miles on my '91 and 58,000 miles on my 2000, and every time I have to check the oil in the auto trans, it P----- me off!
Maybe I'll drill a hole in the case and put a tube in it. Now I just need to borrow me a dipstick. I sure miss my dipstick!
Bob
Bob
'91 Trooper 3.4 V6 ARBs F&R, 33" BFG, 3.07 Teralows, 5.38 F&R, 4" lift, boulder bars, roof rack, torsion bars, Matt's tie-rod ends, manual hubs, heavy springs, homemade front and rear bumpers,rock sliderz, etc. 2000 Trooper
[Re: Pilotbob]
#699943
02/24/06 01:39 AM
If my memory does not fail me, the A/T dipstick was a special dealer-installed option on 2000+ Troopers, a part of the big "4x4 Dream Package". That package included selectable lockers on both axles, 4.77 ratios, 33" tires, a turbocharger, a snorkel and some others goodies (like tranny dipstick, top-mounted alternator, 32 gallons gas tank etc).
Oleg Axiom 4WD 2004: OME shocks, 32" BFG Mudders, RockSliderz, OME929+2" spacers, Stinkyfab bent RE rear links, front ARB locker, rear No-Slip locker, DOR front axle lowering kit, custom middle section skid plate, IronMan torsion bars. Deceased Rodeo'02 4WD.
[Re: holger]
#699944
02/24/06 07:43 AM
.... a part of the big "4x4 Dream Package". That package included selectable lockers on both axles, 4.77 ratios, 33" tires, a turbocharger, a snorkel and some others goodies (like tranny dipstick, top-mounted alternator, 32 gallons gas tank etc). Really? .... What a nice dream <img src="/forums/images/graemlins/cheers.gif" alt="" />
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
[Re: Pilotbob]
#699945
02/24/06 03:19 PM
I kind of like having my wrist watch smelling like tranny fluid. Of course I like it better when I came back from Montreal and it smelled like dancers of the canadian "ballet". <img src="/forums/images/graemlins/wink.gif" alt="" />
[Re: HCMP]
#699946
02/24/06 09:25 PM
I kind of like having my wrist watch smelling like tranny fluid. Of course I like it better when I came back from Montreal and it smelled like dancers of the canadian "ballet". <img src="/forums/images/graemlins/wink.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
