Page 1 of 3 1 2 3
Is it safe to but Seafoam down the carb #700193 02/24/06 04:51 PM
leftnutt35 Offline OP
i was reading the direction on seafoam and it says you can pour it down the carb . is this safe ? won't it kill the car whiles its running ? will it harm the carb..
95 SR stock but i hope not for long....
Re: Is it safe to but Seafoam down the carb [Re: leftnutt35] #700194 02/24/06 05:23 PM
rubberband Offline
I've used Seafoam several times and it seems to work well.
Re: Is it safe to but Seafoam down the carb [Re: leftnutt35] #700195 02/24/06 05:26 PM
DarthRaider Offline
I have to say I have never heard of that but then again I live on an island so...Why would you do that and where would you get seafoam in Idaho?
87 Dodge Raider w/mits 2.3 Turbo Diesel 5 speed
Re: Is it safe to but Seafoam down the carb [Re: DarthRaider] #700196 02/24/06 05:37 PM
rubberband Offline
Seafoam is a lubricant and cleaner.
Here check it out. (Can be purchased at autozone) http://stevenbigler.tripod.com/scoutco/id12.html
Re: Is it safe to but Seafoam down the carb [Re: leftnutt35] #700197 02/24/06 06:24 PM
KB2IAW Offline
If you dont have a carburater can you put it in your gas tank ?? <img src="/forums/images/graemlins/confused.gif" alt="" />
1994 montero SR 3.5 v6
City Of Hills Oneonta N.Y. FREEDOM HAS A TASTE,AND FOR THOSE THAT HAVE FOUGHT FOR IT, THE TASTE IS SO SWEET , THE PROTECTED WILL NEVER KNOW .
VENI VEDI DECI <oneontasportsmenclub.net>
Re: Is it safe to but Seafoam down the carb [Re: KB2IAW] #700198 02/24/06 10:01 PM
W
Winston Offline
You can pour it down your carb, just do it very slowly.
'90 Montero XLS (Sold, sadly)
'95 Montero LS 160k
'03 Montero Limited 30k
Re: Is it safe to but Seafoam down the carb [Re: Winston] #700199 02/26/06 02:45 AM
Tycer Offline
Yes, it works well directly into your carb. It will smoke and sputter like crazy so do it very slowly so it wont kill your engine. But,,, it will do wonders for the carbon build-up. If I could describe how much to put in at a time I would say the speed of a pressurized coffee straw. <img src="/forums/images/graemlins/scared.gif" alt="" /> You may have to have someone inside reving up the motor a little bit also.
* * MY 1993 JEEP GRAND CHEROKEE * * RockKrawler Long Arm Lift, 8" of total Lift, Garvin Wilderness Rack, Hella Lights, 285/75r16 Firestone Destination tires.
Re: Is it safe to but Seafoam down the carb [Re: Tycer] #700200 02/26/06 03:09 AM
did it today this stuff is wonderful. going to do it again next weekend then change the oil i think. should change your oil early after doing this treatment ?
Re: Is it safe to but Seafoam down the carb [Re: leftnutt35] #700201 02/26/06 05:03 AM
Nah, not until you run it through the crank case to clean out years of sludge.
Re: Is it safe to but Seafoam down the carb #700202 02/26/06 10:19 PM
Happy Birthday Chris_J Offline
Haha. How'd you like the smoke show? I did it on an my last car volvo with 260,000 miles on it. And wow smoked for a good 15 minuntes. Neighboors loved it.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 7.530s Queries: 16 (0.005s) Memory: 0.6357 MB (Peak: 0.7427 MB) Data Comp: Off Server Time: 2026-06-21 01:40:46 UTC
