Re: Is it safe to but Seafoam down the carb
[Re: Chris_J]
#700203
02/27/06 02:09 AM
same here neighbor came running out side all in a panic wondering what was going on <img src="/forums/images/graemlins/smile.gif" alt="" />
95 SR stock but i hope not for long....
[Re: leftnutt35]
#700204
02/27/06 08:23 AM
Hmmm I am going to give a try.
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
[Re: leftnutt35]
#700205
02/27/06 05:16 PM
Water (distilled) works well to clean out carbon too. Kind of like a steam cleaner. Use a vacuum line (PCV) to suck it slowly into your intake manifold..
'90 Montero XLS (Sold, sadly) '95 Montero LS 160k '03 Montero Limited 30k
[Re: Winston]
#700206
03/02/06 09:52 PM
so is doing it by vacum hose better than down the carb ?
[Re: Chris_J]
#700207
03/02/06 10:11 PM
Haha. How'd you like the smoke show? I did it on an my last car volvo with 260,000 miles on it. And wow smoked for a good 15 minuntes. Neighboors loved it. This alone makes it worth a try <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> Russ <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
GETTIN OLD THATS EARNED Happy trails to you (1)98 Montero SR RB Rock Crawlers BFG 33s Rancho 9000's OME Med coils rear (2)95 4Runner All Pro Nerf bars BFG 32s ARB bull bar Downey 2" rear coils Downey headers (3) 90 Montero LWB 3.0 auto (4) 98 Kawi GPZ1100
[Re: leftnutt35]
#700208
03/05/06 06:13 AM
Also may want to think about changing out the spark plugs after the sea foam treatment. Or, just wait to use Sea Foam until you are ready to change sparkplugs. And yes, from what I've read on JU it would be a good idea to change oil after using.
-Grant '98 Montero with 135k miles
[Re: MontyGrant]
#700209
03/05/06 09:39 AM
Seafoam comes in a pressurized spray can that will atomize the chemical as you spray it down your carb using the straw that comes with it. I believe the pressurized spray version is called "Deep Creep" and cost roughly the same as standard Seafoam. According to the can, it's basically pressurized Seafoam. This will at least reduce your worries of pouring it in too fast. Good Luck!
Joel, CA
#700210
03/06/06 06:20 PM
I just Deep Creeped my 95 last week. It has ~130k and blew out a bunch of smoke afterwards. Then, I really felt that it immediatley ran with a bit mre response. Note that I am definitely going through oil, and am not losing it on the ground. (Valve seals...???) And when I did the t-belt, the intake was fairly slimy with oil-goo that I cleaned out.
So I then used the Deep Creep on the wife's 98. (~65k and no signs of any oil issues.) It only blew a little smoke out, and I can't say that I felt the same about improved respinse either.
Bottom line, I think that the higher miles 95 needed it, and benefited from it.
Also, the 95 had developed a bad lifter tick. I put a can of regular Seam Foam into the crank and after a 200 mile x2 trip, the tick seems to be gone.
So far I am a happy camper... <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: MontyMcV]
#700211
03/07/06 04:28 AM
I put a can of regular Seam Foam into the crank and after a 200 mile x2 trip, the tick seems to be gone. Did you leave the Seafoam in the oil as you drove the entire 400 mile trip? I'm just wondering since the instructions on the can didn't really say anything about weather to leave it in or not- or how long it can be left in. I basically thought it was to be used as a pre oil change "flush". I asked this question before since i have a vehicle with lifter tick and am to lazy to remove the lifters and clean em out in diesel fuel. The responses at the time wasn't too definite. Joel, CA
#700212
03/07/06 05:29 AM
Joel,
I seem to have cured my lifter tick at least for now. I used 1/2 a quart of Marvel Mystery Oil.
Clay
KG6VNX
