lubricate #701526 03/01/06 01:34 AM
Hal2000 Offline OP
I was just reading the owners manual and saw that I need to lubricate the hinges and other parts and was wondering what do y'all use?
98 Sportage
Re: lubricate [Re: Hal2000] #701527 03/01/06 02:19 AM
Axe Man Offline
Kia Moderator Emeritus
White lithium grease in a spray can.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: lubricate [Re: Axe Man] #701528 03/01/06 02:24 AM
Hal2000 Offline OP
tnx axe man.. now if I could just figure out what is squeaking in the front passanger side..
98 Sportage
Re: lubricate [Re: Hal2000] #701529 03/01/06 02:29 AM
Axe Man Offline
Is the squeak in the front suspension? If yes you might have a bad lower ball joint. They start squeaking when worn out.
Re: lubricate [Re: Axe Man] #701530 03/01/06 04:23 AM
Hal2000 Offline OP
As far as I can tell its in the front somewhere near the tire.
If I push down or pull up on the front passenger side it will squeak
98 Sportage
Re: lubricate [Re: Hal2000] #701531 03/01/06 05:30 AM
Hal2000 Offline OP
If it is the lower ball joints how hard is it to replace them?
I've never had to replace any before.
98 Sportage
Re: lubricate [Re: Hal2000] #701532 03/01/06 01:40 PM
Axe Man Offline
The lower ball joint is held in by 4 bolts then tend to break off when you try to remove them. Least source of aggravation is to have a shop do the work.
Re: lubricate [Re: Axe Man] #701533 03/02/06 08:22 AM
Nukeiridium Offline
Hmm... spray with PB blaster, let soak overnight, then use an impact wrench... I bet they would cooperate smile
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: lubricate [Re: Axe Man] #701534 03/07/06 04:47 AM
Hal2000 Offline OP
You were right Axe. I had someone take a look at the lower ball joint and the boot is torn. So its going to get replaced this weekend..
This is off subject but do any of you use the K&N air filter? The guy whos doing the ball joint replacement told me that he changed his filter with one of these and he noticed a big difference in HP.. He builds and repair race cars out here.
Do they works like he's talking about or is it just a waste of money?
98 Sportage
Re: lubricate [Re: Hal2000] #701535 03/07/06 01:42 PM
Axe Man Offline
IMHO K&N Filters are a waste of money. And that statement is supported by this crew here...
http://bobistheoilguy.com/
Plus, if you put too much oil in them the mass airflow sensor gets contaminated with oil.
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.006s) Memory: 0.6314 MB (Peak: 0.7387 MB) Data Comp: Off Server Time: 2026-10-30 14:53:42 UTC
