Best Brakes
#701583
03/01/06 03:54 AM
My front brake pads and rotors are shot, I was wondering what your guys reccomendations were for pads and rotors
1992 Toyota Regualar Cab Pickup 3.0 V6, 33 10.50 bfgoodrich mt's on 15x8 wheels, all pro offroad flat bed, glass works fenders
Re: Best Brakes
[Re: JA1042]
#701584
03/01/06 04:20 AM
oem are usually best for anything. unless you are getting into vented x drilled and stuff. i used kem...big mistake! wagner kinda stunk too. i do ok with raybestos. as for rotors, id like to know whats better too.
87 4runner 33" bfg mt's no lift. dubbed the marine by my frinds. dead as of august 14 2005. 84 ex cab p/u 33"a/t, 3" suspension+3"bodylift, thorley header and 2.25xhaust, downey midrange cam+rocker set, very milled head! NO RUST!
Re: Best Brakes
[Re: lookmomnobrains]
#701585
03/01/06 04:32 AM
I am not going to go with cross drilled rotors and all that stuff, just like a stock replacement is what i am looking at
Re: Best Brakes
[Re: JA1042]
#701586
03/01/06 05:12 AM
I've have Hawks brake pads in the front, they're OK about as noisy as the OEM.
Hard to tell whats good and whats crap, just stay away from the lower grade DuraLast semi metallics, they squeal like hell <img src="/forums/images/graemlins/scared.gif" alt="" />
Chucky MoMo <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Best Brakes
[Re: JA1042]
#701587
03/01/06 05:49 AM
I have had good luck with OEM pads and shoes and I do not find them noisy. The FJ rotors that are on my front axle are Beck Arnely (sp) that I got at NAPA. They are holding up great. If you are going to be doing wheeling in mud, even a little bit, stay away from cross-drilled or cross-grooved rotors. The mud gets into the holes/groves and wears the pads very quick. Stay away from high speed rated pads, they do not work until they are hot, which will not happen on trail running.
"Serenity through Sobriety"
Re: Best Brakes
[Re: JA1042]
#701588
03/01/06 06:00 AM
Brembo rotors and Akabono pads work really well for me.
I've found the best pads for the money are PBR, Axxis, Repco, Bendix. These's are just some of the under brand names that are made in the same plant in AUSTRALIA. These pads are pretty cheap and dont fade or dust.
Re: Best Brakes
[Re: BennyBoy]
#701589
03/01/06 08:02 AM
stock rotors with pfc carbon metallic pads does it for me
91 pickup 5.29's US GEAR.35x 12.50 trxus m/t.5 speed swap- SOLD! 96 4Runna limited-toytec/OME lift,diff drop Nitto 285/75/16 Elocked=butter 07 FJ cruiser 3" DR coilovers 285/75/16 nitto TG. allpro sliders
Re: Best Brakes
[Re: willzrunna96]
#701590
03/01/06 08:51 AM
I've got the Beck Arnley rotors too on my truck, just replaced them last week, name of the pads escapes me tho.... <img src="/forums/images/graemlins/zombie.gif" alt="" /> you might want to reback your bearings while you're in there, you're taking the hub off anyway to get to those rotors, well at least I had to on my '86 <img src="/forums/images/graemlins/smile.gif" alt="" />
-1986 TOYOTA 22R ZUK coil rear Torqued T-Bars Marlin HD clutch
AZTTORA #492 TLCA member
"I hear there's rumors on the Internets that we're going to have a draft." --George W. Bush
Re: Best Brakes
[Re: 4WD22R]
#701591
03/01/06 04:12 PM
Brembo stock replacement rotors,
OEM pads!!
smooth as glass for years!
Re: Best Brakes
[Re: Staceman]
#701592
03/01/06 05:22 PM
I think Napa OEM replacement pads are good. I have them on the front and rear of our 1990 Supra and no problems. Only 3 ways to make a brake pad... riveted or glued. Semi metalic, organic or full metalic (race pad). then you got shims or no shims. I don't see the point in blowing a lot of money on OEM pads. I have Autozone shoes on the back of my truck for the past 3yrs, no issues, still lots left and no noise. the front I have napa's that came with my D44 reman loaded calipers. no noise, lots left.
94runner: Dana 44 SAS, 35's, Lockers, gears, winch, rock rails, bumpers, 3"BL, drivetrain lift, Budbuilt cross member, centerforce clutch and MORE! ***FOR SALE*** $8,500 -1985 Supra (STOCK!) FOR SALE $4,000 www.celicasupra.com
