Page 7 of 7 1 2 3 4 5 6 7
Re: 3.15 and 2.85 T/Case Gears Now Available. [Re: CerOf] #701712 10/17/06 12:13 AM
dannytuned Offline
i have a 2001 u.s. spec montero sport es 3.0l rear disc with 4.636 gears(i counted teeth). can anyone tell me if the 5.29 ring and pinion will work for me, as i believe there is no answer yet whether or not the t-case gears will? i'd really like to get both.
2001+ US spec Montero Sports with the 3.0L and disc brakes came with 4.90 gears stock.
2001Sport 3.0-Headers-Cage-RoofChop-NP231/D300-D44/ARB-Ford9/Yukon/3Link-37's+H1's-PSC Assist-108:1
Re: 3.15 and 2.85 T/Case Gears Now Available. [Re: dannytuned] #701713 10/17/06 02:25 PM
L
Lee N Offline
The 5.29 gears will not fit. You have the large rear diff, so the lowest gearing available will be 4.90s. On the Tcase gears, do you have an auto or a manual? Or in 2001, did they have AWD? Some of us can look in WINCAPS and compare gear part numbers to see which ones might fit.
I'll be away on business for the rest of the week but PM me your VIN and I'll compare numbers.
Lee
'94 LS, 3.0 V6, Auto, completely stock
Re: 3.15 and 2.85 T/Case Gears Now Available. [Re: Lee N] #701714 10/17/06 09:16 PM
dannytuned Offline
thank you for that answer Lee, i have an auto trans, v4a51 i believe, and a manual t-case - 2hi, 4hi, and 4lo. i think my '01 is the last year before the awd model.
Re: 3.15 and 2.85 T/Case Gears Now Available. [Re: dannytuned] #701715 10/19/06 02:06 PM
L
Lee N Offline
Looked in WINCAPS and your T-case uses the same input gear, countershaft gears, and output gear as a 3.5L V6 equipped Gen II SR. So, this means you can use the 3.15 gears for an auto tranny. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Lee
Re: 3.15 and 2.85 T/Case Gears Now Available. [Re: Mister Bishi] #701716 11/22/06 08:43 AM
Yellowhammer Offline
Per a post I saw somewhere:
"Axle Data
Gen 1
2.6, 2.3TD, 2.5TD & 2.5TDI (some) :
front axle = 25 spline, 29mm diameter, diff = 7.25" diameter (low pinion)
rear axle = 28 spline, 30.5mm diameter, diff = 8" diameter
3.0V6 :
front axle = 28 spline, 29mm diameter, diff = 8" diameter (low pinion)
rear axle = 28 spline, 30.5mm diameter, diff = 9" diameter
Gen 2
3.0V6 :
same as Gen 1 except for NH & NJ auto has 7.25" diameter front diff (high pinion) NH & NJ 5sp man has 8" diameter front diff (high pinion)
2.5TDI :
same as NH & NJ auto
3.5V6 & 2.8TDI :-
front axle = 28 spline, 29mm diameter, diff = 8" diameter (high pinion)
rear axle = 31 spline, 33.5mm diameter, diff = 9.5" diameter"
Do high and low pinion refer to taller or shorter pinion gears on the ring gear assembly or the input pinion? Are these what affect whether the 2.85 or 3.15 gears can be used?
1991 Montero LS 3.0 5-Spd LWB 31" Bridgestone Dueller ATs on stock rims, tan/tan interior/exterior
1986 Isuzu Trooper 2.3 5-spd - partially disassembled, tan interior/dark blue exterior
Re: 3.15 and 2.85 T/Case Gears Now Available. [Re: Yellowhammer] #701717 11/22/06 01:01 PM
No, High pinion is that the propshaft is above the axle centerline, Low pinion is below axle centerline. No affect as far as transfer case goes.
Re: 3.15 and 2.85 T/Case Gears Now Available. [Re: OldColt] #701718 11/23/06 02:48 AM
Okay thanks. I was thinking about the 5.285 ring gears... My brain was on a tangent... and then I mixed the t-case thread and the diff thread in my mind... surprise surprise...
So, the 2.85 T-case gears would be the only one's to fit my 91 3.0 5-speed?
Thanks for answering my questions.
PHP: 7.4.33 Page Time: 0.020s Queries: 15 (0.015s) Memory: 0.6320 MB (Peak: 0.7233 MB) Data Comp: Off Server Time: 2026-11-19 05:28:34 UTC
