Page 4 of 6 1 2 3 4 5 6
Re: 4wd Long travel suspension [Re: surlynkid] #702325 04/23/06 01:14 AM
Jake97T Offline OP
i see, well um...i have...uh boxes and boxes full of cool stuff right now... <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: 4wd Long travel suspension [Re: Jake97T] #702326 04/25/06 07:39 AM
fishy97t100 Offline
anybody know of a solution for relocating the windshield wash bottle on 97 T100s, its right in the wheel well area of the passenger side, its more than likely going to be in the way.
..and its ugly (sticks out below the bumper, bug/mud catcher)
look over to your right. the best solution for it is to use a coolant bottle. its square...not oddly shaped like most washer bottle. it fits nicely behind the headlight and infront of the intake. same mounting setup as the coolant bottle. u can drill a hole on the bottom of the bottle and tap the squirt thingy or plumb it to the cap.
looks cleaner...more clearance
1997 T100 SR5 xxcab 4WD 5spd D44, AAM 11.5, dual case
Re: 4wd Long travel suspension [Re: fishy97t100] #702327 06/04/06 02:42 AM
Jake97T Offline OP
The truck is finally off of jack stands and standing on it's four feet by itself...pics to come soon. Still need to weld the droop stops and gusset the bump stops up.
Still need to sell the Superlift if anybody is interested so i can recover a little of what i spent. <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: 4wd Long travel suspension [Re: Jake97T] #702328 07/03/06 01:45 AM
Jake97T Offline OP
what is the factory T100 skid plate made out of??? is it worthy of skidding? dont have one...
Re: 4wd Long travel suspension [Re: Jake97T] #702329 07/03/06 03:40 PM
Plastic, definitely not good for skidding. <img src="/forums/images/graemlins/frown.gif" alt="" />
I know there was some custom designs floating around hear on the board.
Re: 4wd Long travel suspension #702330 07/04/06 03:01 PM
Jake97T Offline OP
so its more of a pebble guard for driving down the freeway...i guess ill have tomake my Superlift skid plate work, its a bit long but while im at it ill just reinforce the frame crossmember with some c-channel bringing it out another inch and bolt it on...
truck should be on the road today, been a long 2 months...
Re: 4wd Long travel suspension [Re: Jake97T] #702331 07/06/06 09:48 PM
Honger Offline
Jake,
Check this link out for the skidplate I had made for the T100. Also, at the bottom of that page is a link to a JPEG image of the fab drawing... feel free to use it for your T100. I know that several other folks here have used the fab drawing successfully as have I. The skidplate works great!
1998 Toyota T100 SR5 ExtraCab 4WD
Re: 4wd Long travel suspension [Re: Honger] #702332 07/07/06 04:22 PM
ErikB Offline
Toyota Moderator
On the old BigToyTrucks mailing list, the factory T100 skid plate was officially known as a "bunny deflector." <img src="/forums/images/graemlins/evil.gif" alt="" />
<img src="/forums/images/graemlins/lol.gif" alt="" />
http://home.4x4wire.com/erik
Re: 4wd Long travel suspension [Re: ErikB] #702333 07/07/06 04:25 PM
Jake97T Offline OP
im going to need more than a "bunny deflector" since at full stuff my front crossmember is about 3 inches from the ground...
Re: 4wd Long travel suspension [Re: Jake97T] #702334 07/07/06 10:27 PM
ErikB Offline
Toyota Moderator
In that case I'd be running some tubes from the front frame crossmember down to the IFS crossmember and then putting a skid over that...
That's got the potential to take some REALLY hard hits. Ones that could take out that IFS crossmember pretty easily if its not braced/protected well.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6401 MB (Peak: 0.7474 MB) Data Comp: Off Server Time: 2026-06-21 01:45:05 UTC
