Page 3 of 6 1 2 3 4 5 6
Re: 4wd Long travel suspension [Re: surlynkid] #702315 03/28/06 07:06 PM
adam Offline
25 is where i have my truck and it works perfect for stuff/droop.
Is that loaded or light?
~Adam
Re: 4wd Long travel suspension [Re: adam] #702316 03/28/06 07:23 PM
surlynkid Offline
fairly light. no spare in the bed. no tools in the bed. i set it to give me straight down at droop and all the way back at stuff. it worked perfect for me.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: 4wd Long travel suspension [Re: adam] #702317 03/29/06 12:54 AM
Jake97T Offline OP
Ive confirmed that a pair of leaf springs on a Chevy back home are 63+ inches long. They are on a wrecked service truck right now....there are more than 5 leaves in the pack, is this a problem or can i just remove a few without any problems? May or may not be a 1 ton spring. <img src="/forums/images/graemlins/baby.gif" alt="" />
Re: 4wd Long travel suspension [Re: Jake97T] #702318 04/06/06 03:35 AM
Jake97T Offline OP
decided to go with the Tundra deaver 3pack add-a-leaf...which for some reason i made a new post for <img src="/forums/images/graemlins/rolleyes.gif" alt="" />...anyway...
Anybody know the diameter and thread count of stock toyota out tie rods...cuz im thinking using a heim joint on the outside with stock inners would do...
Re: 4wd Long travel suspension [Re: Jake97T] #702319 04/22/06 03:34 AM
Jake97T Offline OP
anybody know of a solution for relocating the windshield wash bottle on 97 T100s, its right in the wheel well area of the passenger side, its more than likely going to be in the way.
Re: 4wd Long travel suspension [Re: Jake97T] #702320 04/22/06 12:55 PM
surlynkid Offline
see if a 95-96 will fit. it is between the battery and the master cylinder.
or look for a 88 4runner small one and mount it anywhere. that is what i will do since my chevy master cylinder will not fit with my OEM washer bottle.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: 4wd Long travel suspension [Re: surlynkid] #702321 04/22/06 04:00 PM
Jake97T Offline OP
so your saying your going to have a 95 wash bottle available soon... <img src="/forums/images/graemlins/evil.gif" alt="" />
Re: 4wd Long travel suspension [Re: Jake97T] #702322 04/22/06 07:52 PM
surlynkid Offline
it is available now.
scott
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: 4wd Long travel suspension [Re: surlynkid] #702323 04/22/06 08:42 PM
Jake97T Offline OP
I dont have alot of room since ive got all kinds of vaccuum lines running around in front of the master cylinder. Behind the battery is my fuse box.
your compartment looks like this...?
Mine looks like this...no room...
Re: 4wd Long travel suspension [Re: Jake97T] #702324 04/23/06 12:42 AM
surlynkid Offline
yes, mine looks like the first pic except for having a GM master cylinder and OBA. <img src="/forums/images/graemlins/smile.gif" alt="" />
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
PHP: 7.4.33 Page Time: 3.394s Queries: 16 (0.007s) Memory: 0.6400 MB (Peak: 0.7641 MB) Data Comp: Off Server Time: 2026-11-14 10:15:48 UTC
