mad shake #704029 03/08/06 02:29 AM
bud89 Offline OP
89 cherokee when riding at speeds of 45mph or faster when i hit a but in the road the front end shakes real bad just wondering if it could be the suspension arm bushings.
Re: mad shake [Re: bud89] #704030 03/08/06 02:41 AM
JeePete Offline
Yes, I suppose it could be, it could be a bunch of other things as well. Individually or together. Ball joints, tie rod ends, track bars, wheel bearings, u-joints, steering damper, even lug nuts also need to be checked. (assuming you have all those things) <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: mad shake [Re: JeePete] #704031 03/08/06 02:44 AM
bud89 Offline OP
i repaced the balljoints,tierods,trackbar,dampener,now i'm replacing the ujoints
Re: mad shake [Re: bud89] #704032 03/08/06 02:46 AM
Tikitgvr Offline
not sure if it would happen on a jeep, but I had a ford that when you did that it shake from side to side really bad and you would need to stop just about to get it to stop.....It was a bad stering pump....the valve inside was bad
Re: mad shake [Re: bud89] #704033 03/08/06 03:16 AM
JeePete Offline
Tires and their pressures can also be a factor as can front end alignment. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: mad shake [Re: bud89] #704034 03/08/06 03:19 AM
W
wyleone Offline
A bad shock(s)? I had one blow out on me and having one blown is much worse than both. It will do some scary stuff when you hit a bump, including change lanes w/o using the steering wheel. Check for oil leaking from one or both. Do the old bounce on the bumper trick. It will be very obvious if one is blown. BTW it does not have to leak to be bad, a broke loose valve inside will do it. I've seen new ones do it.
Re: mad shake [Re: bud89] #704035 03/08/06 06:20 AM
cuervo25 Offline
double check all of those things to make sure they are as tight as you can get them.if they are even slightly loose that could cause a problem. how recent did you replace them,and what size tires do you have?
Re: mad shake [Re: cuervo25] #704036 03/09/06 05:29 AM
bud89 Offline OP
i replaced everything with in the last 2 months 31in. tires brand new bf goodrich t/a replaced suspension control arms today and ujoints. still a little shake but not as bad
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6170 MB (Peak: 0.6993 MB) Data Comp: Off Server Time: 2026-10-22 10:39:22 UTC
