IAT Sensor #704865 03/10/06 05:07 AM
josh_jeeper Offline OP
i have a 1989 jeep cherokee and i was wondering if i had a IAT sensor???? Also if i do where is it????/
Josh Stefani
Re: IAT Sensor [Re: josh_jeeper] #704866 03/10/06 06:17 AM
I know the 91 HO's had an IAT. Your should as well, I don't know where it is. Look on the manifold for a smallish sensor that looks like it is in the air stream, and look on the intake plumbing.
A chilton should say where it is if it has one and what excepted values for it are...
Re: IAT Sensor #704867 03/10/06 01:51 PM
XJCreeper Offline
On the 4.0L MPI motor the IAT sensor is a 2 wire threaded sensor that is screwed into the aluminum intake manifold in front of the throttle body. Here a diagram to help you locate it. If you have the TBI it may not be in the same exact location but in the same vicinity.<img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: IAT Sensor [Re: XJCreeper] #704868 03/11/06 05:11 AM
Yeah thats for a 1990 or newer i think because of the circle throttle body........but i dont know do you knwo what year it is??? Becuase mine is a 1989 and they have a differnt set up then the 1990 and newer
Josh Stefani
Re: IAT Sensor [Re: josh_jeeper] #704869 03/11/06 07:09 AM
91 and newer has the High Output 4.0 EFI engine. The 87-90 4.0 used in cherokee's runs a renix system. IAT is needed to run a good, true, closed loop system. I'm not 100% sure if yours has one, but I'm guessing it does. Look for a sensor on the air box or a sensor on the manifold. If you think you found it, pull it out and eyeball it, Get a good feel for how deep it goes. If it is deep enough to be in the air stream, it's probably an IAT.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.5983 MB (Peak: 0.6626 MB) Data Comp: Off Server Time: 2026-07-13 04:52:16 UTC
