Front Solid Axle Conversion #704932 03/10/06 10:29 AM
bjopii Offline OP
Hello I was wondering if anone could help me. I'm looking for a front solid axle conversion for my isuzu trooper 90 model. do anyone know where i can get this???
Re: Front Solid Axle Conversion [Re: bjopii] #704933 03/10/06 01:52 PM
strawmyers Offline
Isuzu Moderator
It's really just a matter of gathering all of the individual parts it will take to achieve the particular set-up you want. There's a dozen or so different suspension designs just off the top of my head. www.independent4x.com carries a lot of the brackets, plates, and steering stuff to do a SAS. Do a search in these Isuzu forums for +SAS and set the time back to 4 years and you'll have plenty of reading to keep you busy for awhile. Good luck <img src="/forums/images/graemlins/kewl.gif" alt="" />
Sean Strawmyer
Re: Front Solid Axle Conversion [Re: bjopii] #704934 03/10/06 02:08 PM
RobG Offline
you won't find an all-in-one kit for Isuzu SAS. You can either pay a fab shop to do the research and work for you... or if you plan on doing it yourself, I suggest you hit the search feature... you'll find plenty of info out there.
-Rob
Re: Front Solid Axle Conversion [Re: bjopii] #704935 03/10/06 08:21 PM
spacecab90 Offline
You can start with this thread, this is where i have been going for the past 5 months while doing my SAS.
http://www.4x4wire.com/forums/showf...&fpart=1&vc=1#Post770115
Peace
Joel
1990 Isuzu Spacecab, SAS 95% done
'06 Nissan Sentra SE-R Spec V
Re: Front Solid Axle Conversion [Re: spacecab90] #704936 03/11/06 03:40 AM
Rodeo Clown Offline
PM 4WDJOE here on the forum. He has done one on an early trooper and has some stuff he gathered for doing his second one which is being parted(SAS stuff not the trooper). He would be able to hook you up with what you need to get a SAS done but you will need to be able to cut, grind, and weld to do it or have a buddy that can. <img src="/forums/images/graemlins/kewl.gif" alt="" />
1997 Isuzu Rodeo - Auto - 31" ATs
1995 Honda Passport - 1 tons - 39" Boggers
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6047 MB (Peak: 0.6701 MB) Data Comp: Off Server Time: 2026-06-17 07:15:42 UTC
