4D56T turbo wiggle (good / bad) and Boost gauge
#705411
03/12/06 12:32 AM
So swapped out the two front parking lights and rebuilt the headlamp washer the other night (boy does that thing spray, no wonder the impeller would ususaly shatter, good thing mine was just a rusty armature) and since I had the 10mm driver in hand I decided to take off the hose from the air box to the turbo to check it...
Turbine spins freely and the slop I would describe like (sorry if it is a poor analogy) what a M4 bolt would move side to side & up down if it had 6 to 10 threads engauged.. Good? Bad?? <img src="/forums/images/graemlins/confused.gif" alt="" />
Also I am thinking of moving the altimiter and putting a boost gauge in its place. I have to drill and tap the elbow from the turbo to the manifold. Is it better to put this fitting on the side?, Top?, Bottom? Any suggestions? <img src="/forums/images/graemlins/confused.gif" alt="" />
Thanx
97 Prado (LC 90 series) JDM import 2020 --- 2000 Galloper II SWB under offer from Korea 88 Mits Pajero LWB 185000Km 2.5TD JDM import (SOLD)
Re: 4D56T turbo wiggle (good / bad) and Boost gauge
[Re: bill_bly_ca]
#705412
03/12/06 03:09 AM
M-4 as in weapon or fastener? Either way it should have minimal play. Here is what I did with my gauges, stock gauges are crap. ![[Linked Image]](http://pics.montypics.com/okred/2004-04-05/1081174358_dsc01421.jpg) That is boost and oil psi.
A brand spankin new 1973 series 3 Landy OLIVE DRAB SWB, TURBO, IN ABOUT 36 PIECES 89 TROOPER, RESCUED FROM THE YARDS. (Down again) 05 TACOMA CREW SHORTY.
[Re: OKRED]
#705413
03/12/06 04:35 AM
What's that little vent between your guages? What does that do? Mine's covered by the guage pod.
Clay
KG6VNX
[Re: OKRED]
#705414
03/12/06 05:37 AM
lol m4 you must have ties to the army or marines because i think thats still there assult rifle they use
88' Montero SWB 2.6L 5 speed, Got for free from my folks I couldnt stand the car I first drove just sit there and die.
[Re: POLAK50]
#705415
03/12/06 06:21 AM
shaft play is never good in a turbo charger.
RIP raider
[Re: Raider_X]
#705416
03/12/06 08:34 AM
If you allow .002 clearance per bearing surface and there are two surfaces per bearing, that says you can move each bearing .004". Since the bearings are well inboard of the shaft you will see double the movment at the end of the shaft.
Two bearings.. get even more movment.
Bottom line? .022" of movement at the end of the shaft is pretty normal. As long as the wheels have not rubbed the housing your probably OK.
Kevin
[Re: Kevin C]
#705417
03/12/06 02:22 PM
OK... It is not even close to 22 thou.. Maybe 3 to 5 if I had to guess.
[Re: bill_bly_ca]
#705418
03/12/06 03:04 PM
Kevin's .022" sounds right to me. I've successfully used up to 1mm, and .022"=.55mm
Do you have a waste gate? If so, for the boost gauge, tap the waste gate line from the turbo outlet with a tee for the gauge, or for that matter, any manifold tap upstream of the throttle - woops, diesel and no throttle - any tap, including the brake booster line before the check valve. I would avoid any metal drilling unless you are SURE you can get ALL the chips out.
[Re: 52degrees]
#705419
03/12/06 08:22 PM
Clay It's actually just a little access cover for a dashbolt. Plug is behind there for stock guage pod.
[Re: fasteddy]
#705420
03/13/06 03:59 AM
So here then?? ![[Linked Image]](http://www.geocities.com/bill_bly_ca/boost.JPG)
