Going nuts about headlights #705849 03/13/06 12:13 PM
sixpacktr Offline OP
Wondering if anyone can help me. About 3 months ago I spliced the fog lights on my 87 YJ into the headlight system so that they would work when the headlights were turned on. I was having problems with the fog light switch blowing up since it was directly connected to the battery (yes I had an in line fuse, but it still seemed to be a problem). Everything went great til last week, when suddenly the headlights wouldn't come on. The parking lights all worked, the dash worked, the tail lights worked, but no headlights/fog lights. So I bought both the headlight switch and the dimmer switch (one thing I noticed after putting the fog lights in the same wire system as the headlights was that the dimmer no longer worked--when you engaged the dimmer, all lights went out: dash, headlights, tails, parking. So we didn't use the dimmer). First, I replaced the headlight switch, but to no avail, still no headlights. So I replaced the dimmer switch, and voila, the headlights come on. So I pat myself on the back, content that I AM smarter than that darn car! <img src="/forums/images/graemlins/smile.gif" alt="" />
Til this morning. 3 days after replacing the dimmer switch, I went out early to start the car, and there are no headlights! So the car is smarter than me. <img src="/forums/images/graemlins/angry.gif" alt="" /> I checked the fuses under the dash, and they all seem to be okay. What am I missing? This should be a protected circuit, so I can't believe that it blew that quickly.
Any thoughts on what to check for?
98 Ford F150 XLT
68 Triumph TR250
When looking for a reason as to why things go wrong, never rule out sheer stupidity...
Re: Going nuts about headlights [Re: sixpacktr] #705850 03/13/06 03:46 PM
The head light switch is only rated for running those headlights and maybe a little more. How big was the fuse that the fog lamps was burning? I bet you are just overloading the system. Also, fog lamps aren't that powerful most of the time. I would double check there are no shorts.
Re: Going nuts about headlights [Re: sixpacktr] #705851 03/13/06 04:40 PM
BigJim Offline
My advice is to NEVER wire anything into your headlight wiring!! What if you are are in a situation where the lights going out suddenly will KILL someone?
Do like the wiring diagram says on the fog lights and put them on a seperate fused switch! JUST like everybody elses. Do it correctly the first time and you will have no problems.
Re: Going nuts about headlights [Re: BigJim] #705852 03/13/06 05:33 PM
That is what I needed to know. I have another related question now. Does everyone else directly wire their fog lights to the battery? Or is there a fuse/wire somewhere that I should be looking for so that I can tie it to that?
Thanks again for the help.
98 Ford F150 XLT
68 Triumph TR250
Re: Going nuts about headlights [Re: sixpacktr] #705853 03/13/06 07:51 PM
BigJim Offline
YES you need an inline fuse and it should be VERY close to the source!
Re: Going nuts about headlights [Re: sixpacktr] #705854 03/14/06 06:51 AM
For 1 or 2 things, wiring directly to the battery won't hurt. If you plan on doing a lot of after market modifications that will require lots of power, consider getting a generic fuse box and running everything off of that.
Re: Going nuts about headlights #705855 03/14/06 09:54 PM
He's probally got relay issues now.
Re: Going nuts about headlights #705856 03/15/06 03:02 AM
Got an inline fuse and drew the power off of the battery instead of the headlights, and everything works like it should. Thanks again for the help. I now know not to tie other lights to the headlight switch.
Thanks again.
98 Ford F150 XLT
68 Triumph TR250
Re: Going nuts about headlights [Re: sixpacktr] #705857 03/15/06 05:09 AM
W
wyleone Offline
Just an offshoot experience so I guess it is slightly OT. I had learned this in a similar way. I was in HS and I had my baby, an 84 Cavalier F41 Conv. I tied in some pain ol' Walmart clear lens driving lights to the headlamp ckt. While driving through the mountains in WV at 3am I was in a fog, really tired and the interior of the car filled w/ smoke and the headlamps (and DL) cut off at 65mph going down the mountain. <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> Turns out I melted the headlamp switch bigtime from the overheat. I pulled the harness through the hole where the HL switch belonged and I stripped the wires back w/ a dull knife. I still have the scar on my chin from that knife slipping in the dark. <img src="/forums/images/graemlins/shiner.gif" alt="" /> AHHH Memories, thanks for bringing that one back. <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Going nuts about headlights [Re: wyleone] #705858 03/17/06 04:21 AM
fishtaker Offline
so you learned that you should keep your knife sharp after that?????
I had a 69 chevy p/u with the floor mount dimmer switch that one night I pressed it to drop to low beams. Well the guy that put the switch in wasn't too bright and left a piece of wire exposed on the terminal. When I pushed the dimmer, the wire shorted and I lost low beams. I was in the middle of no where and all was ok till I blinded the oncoming car with my brights and of course, he was a state trooper. Luckily, didn't cost me anything more than replacing the hl switch and the dimmer.
03 TJ 5 Speed I-6 30X9.50 BFG KO's
PHP: 7.4.33 Page Time: 2.184s Queries: 16 (0.004s) Memory: 0.6317 MB (Peak: 0.7552 MB) Data Comp: Off Server Time: 2026-06-09 23:58:04 UTC
