Clutch adjustment? #706232 03/14/06 02:39 PM
The clutch in my '95 Sidekick doesn't engage til the pedal is almost to the floor. Can I adjust this with the locknut at the end of the cable, or do I have to move the bracket that the cable is mounted to? My Haynes manual is sort of confusing me <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Clutch adjustment? #706233 04/01/06 11:22 AM
O
oregonzuki Offline
i have a 96 sidekick that ran into the same problem as you. i simply just crawled under and tightened the nut on the threaded bolt of the clutch wiring. block the wheels for safty and have someone push the clutch for adjustment.
Moderated by  4x4Wire, code33
PHP: 7.4.33 Page Time: 0.006s Queries: 14 (0.004s) Memory: 0.5814 MB (Peak: 0.6286 MB) Data Comp: Off Server Time: 2026-06-18 12:01:13 UTC
