Page 2 of 3 1 2 3
Re: :( Where do these wires go!? [Re: 87Toy4x4] #706407 03/16/06 06:59 AM
Nix_Toy Offline OP
Hmm.. Where you plugged in your yellow connector, I plugged in the green one... I did that because the yellow one was the only plug of that type that would reach on top of the engine near the thermostat housing... so I'm wrong, right? smile There is no possible way that the green plug would reach the top of the engine unless I spliced some more wire into it...
Re: :( Where do these wires go!? [Re: Nix_Toy] #706408 03/16/06 05:25 PM
Nix_Toy Offline OP
Ok, I got all of them except this one? Any takers? <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: :( Where do these wires go!? [Re: Nix_Toy] #706409 03/16/06 06:03 PM
that one doesnt' go to the idle air servo hanging under the throttle body? there should be a plug for it on the backside of it. I kidna remember that connector bieng blue for some reason. that particular style connector is only used for the four main injectors, the cold start injector, and the idle air servo. I think the turbos used the same connector for the cruise control, but I'm not 100% on that.
what, exactly, did your harness come from?
Re: :( Where do these wires go!? #706410 03/16/06 06:40 PM
Nix_Toy Offline OP
thanks sundowner i found it, i think
Hey 87toy4x4, i have one connector left that looks like the yellow one in your second picture but it is green. any idea where that one goes?
Re: :( Where do these wires go!? [Re: Nix_Toy] #706411 03/17/06 04:22 AM
Nix_Toy Offline OP
Anyone know? It's the last wire.. I'll give someone with the correct answer 45 cents! <img src="/forums/images/graemlins/drunk.gif" alt="" />
Re: :( Where do these wires go!? [Re: Nix_Toy] #706412 03/17/06 05:35 AM
87Toy4x4 Offline
there are a lot of green connectors so im not really sure which one that is but i have two pics of where green connectors plug in.
in this pic the green plug is in the top right. im not really sure where that plugs in but i know i never unplugged any of the green ones. i took the whole intake manifold off w/o disconnecting the wiring harness.
click on the pic to make it bigger.
heres another pic where a green connector like that one plugs in.
THESE PICS ARE NOT FROM MY ENGINE! haha that engine i took out of that runner was gross.
Re: :( Where do these wires go!? [Re: 87Toy4x4] #706413 03/17/06 07:03 AM
4WD22R Offline
Hmmm looks like that valve cover was leakin a bit huh <img src="/forums/images/graemlins/zombie.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: :( Where do these wires go!? [Re: 4WD22R] #706414 03/17/06 07:20 AM
87Toy4x4 Offline
EVERYTHING was leaking haha. plus it wasnt just oil, coolant was mixed w/ it b/c of the head gasket lol. it was such a pita swapping that thing b/c i got covered in oil and dirt each time i worked on it. that is why i try to keep my engine and truck clean. this one's mine. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: :( Where do these wires go!? [Re: 87Toy4x4] #706415 03/17/06 09:04 AM
4WD22R Offline
Purrrrrrrty!!
You wanna clean mine? <img src="/forums/images/graemlins/smile.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
--George W. Bush
Re: :( Where do these wires go!? [Re: Nix_Toy] #706416 03/17/06 01:58 PM
From the location of it with in the harness, it looks like it goes to the little modutator with the coolant lines under the intake. But that is on a 22re I don't even know if your 22r has one of those things.
I do know that the type of plug it is, it is definately a sensor and not just the other end of a harness to something else like the rest in that pic.
Good luck
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.007s) Memory: 0.6426 MB (Peak: 0.7513 MB) Data Comp: Off Server Time: 2026-11-16 08:47:26 UTC
