Cylinder misfire code P0301 / 96-T100 #707053 03/17/06 05:23 AM
Replaced plugs, wires and then still had cylinder #1 misfire
So I switched Ignition coils from #1 to #3 and #3 to #1 to see if it was the Ignition coil but still came up with a #1 cylinder misfire!
could it be a faulty Injector?
Any one have any thoughts?
Re: Cylinder misfire code P0301 / 96-T100 #707054 03/17/06 05:37 AM
Jake97T Offline
did you try switching just the spark plug from cylinder 1 to see if you got a misfire??? are you using denso plugs or another brand?
Re: Cylinder misfire code P0301 / 96-T100 #707055 03/17/06 07:02 AM
Squeezer99 Offline
fuel injector? valve adjustment?
Re: Cylinder misfire code P0301 / 96-T100 #707056 03/17/06 02:44 PM
I replaced all plugs with new Denso plugs and wires and still got the #1 Misfire code then I switched the ignition coils from #3 to #1 and still got the #1 Misfire code
I think if it was the #1 Ignition coil it should have registered a #3 misfire when it was switched
Re: Cylinder misfire code P0301 / 96-T100 #707057 03/17/06 06:18 PM
garym Offline
Did you reset the codes in the computer after the change?
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Re: Cylinder misfire code P0301 / 96-T100 [Re: garym] #707058 03/17/06 07:39 PM
Codes were reset each time and also test driven each time that I did any one thing so I would know what might have worked
Re: Cylinder misfire code P0301 / 96-T100 #707059 03/17/06 08:03 PM
Jake97T Offline
I would still go back to the spark plug itself in cyclinder #1, being the cheapest part that could be problematic replace that with a plug from another cylinder with your coils in the correct order etc and see if you get misfire on the cyclinder the spark plug from #1 went into...
Re: Cylinder misfire code P0301 / 96-T100 [Re: Jake97T] #707060 03/18/06 02:40 AM
J_Bird Offline
I think he's trying to tell us, he had this problem before he put on these new parts.
Re: Cylinder misfire code P0301 / 96-T100 [Re: J_Bird] #707061 03/18/06 03:07 AM
Thats correct
Re: Cylinder misfire code P0301 / 96-T100 #707062 03/18/06 03:46 AM
Jake97T Offline
oh okay...i see... <img src="/forums/images/graemlins/zombie.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6265 MB (Peak: 0.7310 MB) Data Comp: Off Server Time: 2026-06-23 12:25:38 UTC
