Vacuum at idle #707318 03/17/06 09:31 PM
4WD22R Offline OP
Just a quick question for you guys and gals:
What kind of vacuum should a '86 22R pull at idle? Mine's pullin about 21 In/Hg and I can drop it to 0 In/Hg by putting the throttle all the way down...
Sound about right?
Thanks!
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: Vacuum at idle [Re: 4WD22R] #707319 03/18/06 01:57 AM
1
1986xtracab Offline
that is perfect. a good running engine should have 17- 21 at idle, OH and it should be steady and not bouncing.
Re: Vacuum at idle [Re: 1986xtracab] #707320 03/18/06 03:50 AM
4WD22R Offline OP
what is bouncing? mine moves about 1 in/Hg that good?
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
--George W. Bush
Re: Vacuum at idle [Re: 4WD22R] #707321 03/18/06 04:25 AM
4Crawler Offline
Re: Vacuum at idle [Re: 4Crawler] #707322 03/18/06 09:13 PM
4WD22R Offline OP
<img src="/forums/images/graemlins/kewl.gif" alt="" /> Thanks Roger! Guess it's time to go check the gap in the ole spark plugs <img src="/forums/images/graemlins/smile.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
--George W. Bush
Re: Vacuum at idle [Re: 4WD22R] #707323 03/19/06 12:06 AM
willzrunna96 Offline
ok whill the topic is up rather than starting a new one.... i pull a steady 19 at idle and at 3000 rpms the needle fluctuates between 20-24. what could cause this..is this normal. as you all no im still trying to figure out my rough idle situation...any ideas
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6121 MB (Peak: 0.6817 MB) Data Comp: Off Server Time: 2026-05-28 01:40:19 UTC
