Napa carb rebuild kit problems #707632 03/19/06 03:13 AM
Ryan_Vazquez Offline OP
I have a napa rebuild kit for my carburetor. The aap diaphram in the kit doesn't line up with the holes. This is an extra carb, but the one currently on my truck was also rebuilt with a napa kit and its aap broke so i replaced it with the original one off my spare carb and I now see that both the napa diaphrams have the holes in the same place.
The accelerator pump in the kit also is different from the original. The metal part on the inside of the original has a continuous round lip, while the napa part has a divot about a mm or 2. Is this a problem or will it work OK
Its for a 1985 22R
I am contemplating trying to return the whole kit and finding another. Does anyone know of any good alternatives. Can I get an oem kit?
thanks for any help
Ryan
Re: Napa carb rebuild kit problems [Re: Ryan_Vazquez] #707633 03/19/06 04:10 PM
ArbitraryNotion Offline
I normally use the GPSorensen kit from Autozone. AAPs in from any aftermarket kit will still need to be replaced about every 2 years I've found. Best thing is to buy the AAP from toyota.
1986 Toyota 4x4 22wEBer
Ported EB Offroad H/O Head "Josh Cam"
Ported Intake & Weber38mm Carb
LCE Header & 2.25in Exhaust
RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
Re: Napa carb rebuild kit problems [Re: ArbitraryNotion] #707634 03/19/06 05:09 PM
Scerb Offline
You tried flipping it over to line up the holes, right? I remember I couldn't get mine to line up.. till I flipped it over <img src="/forums/images/graemlins/drunk.gif" alt="" />
-Scerb
Re: Napa carb rebuild kit problems [Re: Scerb] #707635 03/19/06 05:23 PM
-Scerb
Thats what I was thinking when i went to sleep last night. Although it looks like it should go the other way in the FSM <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Napa carb rebuild kit problems [Re: Ryan_Vazquez] #707636 03/19/06 06:04 PM
MAC Offline
over the years i had 2 aap rubbers from rebuild kits. one was n/g to begin with, the other did not last long. i recommend bite the bullet and fork over the $ for the toy part and your done for many years of service.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6054 MB (Peak: 0.6704 MB) Data Comp: Off Server Time: 2026-07-14 12:17:43 UTC
