We have progress! I've got the frame cut where I want the rear spring mount, put the 'outside' plates in that true up the bend in the frame. The front spring hangers are installed and about 1/2 welded solid. (pic 3)
Notice the difference in the radiator core support? The lack of the part that hangs down? I cut that out and put a piece of angle iron in there, along with a cross out of round stock that you can't see behind the AC condenser. (pic 2)
The winch slides under the condenser and shouldn't stick out much, if any, further than the factory grill. I'm not sure what I'm going to do for a bumper or tow/recovery points yet.
The springs are going to sit pretty close to level and I'm still hoping that even SOA it's not going to be insanely tall.
I've also moved the radiator core support mounts/front body mounts on top of the frame. I've got more time in the core support reworking than I do in the spring mounts.
The little 'stubs' of frame sticking out are 2" X 1/4 wall that's pounded down inside the frame and welded in several inches back where it hits the factory tubes, and is also welded to the front of the frame/cross member. 2.5" 1/4 wall is over the top of that, welded to the frame, and the inner 2" box. Those stubs aren't ever going anywhere. Add to that all the individual pieces will be bolted together before it's finished. If my 400 miles of welds fail, bolts will keep it in one piece while we, or someone else, are dangling off the winch. Not being an engineer(neither was my Dad) I was taught to built it 10X heavier and 3X stronger than it has any need to be.
Note my super $12 spring alignment tool? 1" DOM .120 wall with 3/4" round stock inside that, with the ends turned down to fit the bushings. Even after welding I can slide the pins through all 4 of the holes for the front shackle mounts with minimal fussing and the amount of slop in the setup is also minimal. I figure spring bushings and manufacturing tolerances are probably as sloppy as the tool.
I kind of wish you could resize the edit window... And sorry for the messy text.
Comments? Questions? Let me hear it. <img src="/forums/images/graemlins/smile.gif" alt="" />
![[Linked Image]](http://mysite.verizon.net/res6sw0u/amigo/solid axle/frame extension 5.JPG)
