cheap winch mount? 89 pickup
#708068
03/20/06 03:39 PM
hey guys, looking for a cheap way to mount my 9k winch to my 89 toyota pickup. would like to mount it up front and obvoiusly make it real stout... any ideas? cheap is key! can do some welding if i have to...
thanks kevin
22RE OWNERS CHECK FOR DEBRIS IN YOUR OIL PANS! YOU MIGHT SAVE YOUR MOTOR!*** 1989 Toyota pickup 22re 5spd 4wd *** * New mods * - 305/70/R16 (33X12.5)
- 2 in suspention lift (zuk coils)
- minor body work
Re: cheap winch mount? 89 pickup
[Re: ToYPU]
#708069
03/21/06 02:51 AM
Weld up a framice(frame like device) that holds it where you want it, should be easy and if you use 3/8 inch think steel with gussets, it wont break.
[Re: trythis]
#708070
03/21/06 03:32 PM
look at the front of the frame, there are some stock bolt holes on the bottom. I ran two heavy pieces of angle iron from those and but a plate on the top.. it sticks out kinda far.
[Re: missouriman]
#708071
03/21/06 07:55 PM
did you oversize the holes and use thicker bolts? how big is your winch?
thanks! kevin
- minor body work
[Re: ToYPU]
#708072
03/23/06 12:06 AM
Here's some ideas: In my first try I built this bumper for about $160 or so. first versionI later reworked the mounting to raise it up at an additional cost of $80. final versionThere are a few more pics of each if you follow the links to my photobucket pics.
[Re: indy]
#708073
03/23/06 01:19 AM
nice job! doesnt look to expensive... just gotta talk my friend into doing some welding!
kevin <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" />
- minor body work
PHP: 7.4.33 Page Time: 5.987s Queries: 15 (0.004s) Memory: 0.6094 MB (Peak: 0.6795 MB) Data Comp: Off Server Time: 2026-06-18 13:35:52 UTCValid HTML 5 and Valid CSS
