advice please on diffrent axel placement on spring #708168 03/20/06 08:13 PM
BJWEST Offline OP
has any one ever re drilled and pined a set of springs to move the rear axel further back on them? pros? cons? the reason i ask is i have a 85 excab that is sitting on 63' chevys and i want to bob the bed but with those looooong springs its pointless id be taking of like 3in. so im planning to move my foward spring mounts foward like 8in and then move my axel 8in back on the springs, allowing me to use my old rear spring mounts and allowing me to bob back to the mounts. pleaselet me know if there is a problem with doing this before i start tearing things apart.
Re: advice please on diffrent axel placement on spring [Re: BJWEST] #708169 03/20/06 08:42 PM
4Crawler Offline
The springs will most likely snap where the old center bolt holes were drilled. You might investigate flipping the spring pack around to see if that helps at all.
Re: advice please on diffrent axel placement on spring [Re: 4Crawler] #708170 03/20/06 11:56 PM
BJWEST Offline OP
the holes are dead center
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5925 MB (Peak: 0.6459 MB) Data Comp: Off Server Time: 2026-06-19 02:56:06 UTC
