engine sputters when wet #708390 03/21/06 05:59 AM
idles fine. while driving it will sputter, pop out the exhaust etc while making a "bra..bra... braaaaaah" sound. it does this intermittently while driving and only when its raining or snowing (guess what is going on outside) if there is a dry day, it doesnt do it.
any ideas as to what is going on?
Re: engine sputters when wet #708391 03/21/06 09:19 PM
TimsToyo Offline
Have you checked you distributor cap for cracks? Next time it's raining spray some WD-40 inside the distributor cap and see how it runs. When was the last time you replaced the plug wires? I'm thinking it's somewhere in the ignition side.
'86 Toyo 4wd
'04 600RR
Re: engine sputters when wet #708392 03/22/06 11:36 PM
mnwolftrack Offline
another simple thing to check is to see if the passenger side floor board is rusted through--causing moisture to get to the computer behind the passenger kick panel.
Also check all your spark plug wires, especially for arcing. Plug wires can short out when wet. The easy way to tell this is to first start the vehicle in a dark garage or at night outside and look for any light shows under the hood. If you don't see any, shut the engine off and use a spray bottle and lightly mist the plug wires, distributor cap, and coil wire, restart, and see if you see any light shows then.
Also check the electrical connections at the coil and make sure they are snug.
Are your front wheel well splash guards in place? How about the front skid plate (if '86 or newer) or the splash pan if '85 and older?
Re: engine sputters when wet #708393 03/23/06 05:53 PM
Marc91runner Offline
Also try spraying the O2 sensor leads.
'91 4Runner SR5 V6 4X4 Auto, A/C (self installed)
4.56, 31x10.5x15 Nokian Vatiiva's
Re: engine sputters when wet #708394 03/23/06 10:03 PM
stock87 Offline
If you need to replace the O-ring that goes between the cap and the distributor, it's $2.35 from www.1sttoyotaparts.com, part number 1912715021 (dust packing or some thing)
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
PHP: 7.4.33 Page Time: 0.006s Queries: 14 (0.004s) Memory: 0.6018 MB (Peak: 0.6615 MB) Data Comp: Off Server Time: 2026-06-11 11:12:56 UTC
