Alternator questions - Roger...? #708570 03/21/06 05:22 PM
mental Offline OP
Driving into work yesterday and alternator was overcharging - looked like 18volts or more on the guage. It's about an hour to get there and in an effort to keep from frying the battery, I ran it with all acessories running, lights etc. When I started it up 30 minutes later, not charging at all, dead in the water. Do you think it's worth having rebuilt, or better yet, think I can go about doing it, or is this a professional's domain? I've immersed myself in all other aspects of Ruby's maintenance/upkeep including head gasket, transmission/clutch replacement, but I've never done anything more than Re&Re alternators in the past.
I don't think it matters, but it's an '87 Runner, SR5, A/C, 22RE/W56.
Thanks
Mike
Re: Alternator questions - Roger...? [Re: mental] #708571 03/21/06 06:35 PM
fourwd1 Offline
Rebuilding a n alt isn't that hard. Depends on what's bad and if you can get the parts.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: Alternator questions - Roger...? [Re: fourwd1] #708572 03/21/06 07:07 PM
4Crawler Offline
Have not worked on the Toyota alts (yet)), but it may either be worn brushes or a blown regulator. I know my PPW alternator voltage went way high when the external regulator went out. There is a brush repair article in the Tech section here.
Re: Alternator questions - Roger...? [Re: 4Crawler] #708573 03/21/06 07:15 PM
Scerb Offline
Thats what happened when my voltage regulator died. I believe new they are 50 or 60 bucks, but easy to change. I had a old alternator with good regulator but bad brushes. I swapped regulators with this one and made 1 good alt for free.
-Scerb
Re: Alternator questions - Roger...? [Re: mental] #708574 03/21/06 07:39 PM
DRTDEVL Offline
Check this out, and se if it sounds familiar... I believe all the pics are long gone, but you get the idea as I wrote a step-by-step process as I thought through and attacked my problem.
Ohmic loss thread
Re: Alternator questions - Roger...? [Re: DRTDEVL] #708575 03/21/06 08:49 PM
ErikB Offline
Toyota Moderator
Sounds like a perfect opportunity to upgrade! <img src="/forums/images/graemlins/kewl.gif" alt="" />
http://www.4x4wire.com/toyota/tech/alternator/
(wish I'd known about that when my alternator died a couple of years ago)
The article also show how to disassemble/rebuild.
http://home.4x4wire.com/erik
PHP: 7.4.33 Page Time: 0.009s Queries: 14 (0.006s) Memory: 0.6111 MB (Peak: 0.6811 MB) Data Comp: Off Server Time: 2026-11-15 16:06:48 UTC
