Page 2 of 4 1 2 3 4
Re: Need some help guys..... [Re: 52degrees] #708736 03/22/06 06:17 PM
justdoitmikey Offline OP
this the kind of compressor i need? [Linked Image]
seems like it would be a beeitch to get up in the spring but i will go get one if this is the right kind.
thanks
No Monty anymore!
Looking for a 95 SR in good shape, so keep an eye out!
Re: Need some help guys..... [Re: 52degrees] #708737 03/22/06 06:20 PM
You don't need to do a custom brake line. Here's a stock one you can use for gen I v6 montero's. Not sure if it works for the 2.6L models.
Bendex PN# 7764
Re: Need some help guys..... [Re: justdoitmikey] #708738 03/22/06 06:46 PM
grass13 Offline
NOOOOOO!!!!!! its kind of a pita to get up in there anyways, so i recommend going with the one sided ones. they come in a set, and you put one on each side torque one some then the other and visa-versa until the springs can be pulled out. if you go with the kind you posted... i can already think of about 1000 four letter words that i would end up using tring to get them into the springs.
Re: Need some help guys..... [Re: grass13] #708739 03/22/06 07:07 PM
ya me too thats why i didn't want to use that kind, thats why i wanted to do it without the spring compressor. I hate the one sided ones even more tho. unless you do them evenly it pulls them to one side.... grrr.
No Monty anymore!
Re: Need some help guys..... [Re: justdoitmikey] #708740 03/22/06 07:10 PM
grass13 Offline
yeah its a pita either way... or if you wanted to make it a huge pita, you could just disconnect everything and drop the axle. btw, glad that p/n got posted for the brake line... im going to be going to longer shocks sometime this summer after i beef up my trailing arms.
Re: Need some help guys..... [Re: grass13] #708741 03/22/06 07:12 PM
ya thats what i did last night, saw i couldn't get enough droop with the brake line attached so scrapped the idea. Maybe a shop will do it for like $50.... im gonna make some calls
No Monty anymore!
Re: Need some help guys..... [Re: off-roader] #708742 03/22/06 07:27 PM
That bindex hose is a good bit longer then stock I guess?
I think im just gonna take the shocks loose and the hose off drop the rear end and do it that way, then have the compressors as a back up. Im thinking bleeding the system is less evil then those stinkin spring compressors....
No Monty anymore!
Re: Need some help guys..... [Re: justdoitmikey] #708743 03/22/06 08:02 PM
Yes, the new p/n is longer than stock (~2").
Here's a write-up on the club website.
http://www.geocities.com/mitsubishifourwheeldriveclub/FAQ-Lift.html
Re: Need some help guys..... [Re: off-roader] #708744 03/23/06 02:10 AM
Tag Offline
Is the longer hose the same part number for the SWB? I am glad this topic came up. I forgot I could stand to change it for a longer one.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: Need some help guys..... [Re: Tag] #708745 03/23/06 02:25 AM
dang.. I just replaced mine. Dont tell me i goto do it all over again when i lift it. I never thaught those compressors where so bad. Just need to take your time.
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6424 MB (Peak: 0.7509 MB) Data Comp: Off Server Time: 2026-06-20 22:17:55 UTC
