Re: Need some help guys.....
[Re: 52degrees]
#708736
03/22/06 06:17 PM
this the kind of compressor i need? seems like it would be a beeitch to get up in the spring but i will go get one if this is the right kind. thanks
No Monty anymore! Looking for a 95 SR in good shape, so keep an eye out!
[Re: 52degrees]
#708737
03/22/06 06:20 PM
You don't need to do a custom brake line. Here's a stock one you can use for gen I v6 montero's. Not sure if it works for the 2.6L models. Bendex PN# 7764
[Re: justdoitmikey]
#708738
03/22/06 06:46 PM
this the kind of compressor i need? NOOOOOO!!!!!! its kind of a pita to get up in there anyways, so i recommend going with the one sided ones. they come in a set, and you put one on each side torque one some then the other and visa-versa until the springs can be pulled out. if you go with the kind you posted... i can already think of about 1000 four letter words that i would end up using tring to get them into the springs.
[Re: grass13]
#708739
03/22/06 07:07 PM
ya me too thats why i didn't want to use that kind, thats why i wanted to do it without the spring compressor. I hate the one sided ones even more tho. unless you do them evenly it pulls them to one side.... grrr.
[Re: justdoitmikey]
#708740
03/22/06 07:10 PM
yeah its a pita either way... or if you wanted to make it a huge pita, you could just disconnect everything and drop the axle. btw, glad that p/n got posted for the brake line... im going to be going to longer shocks sometime this summer after i beef up my trailing arms.
[Re: grass13]
#708741
03/22/06 07:12 PM
ya thats what i did last night, saw i couldn't get enough droop with the brake line attached so scrapped the idea. Maybe a shop will do it for like $50.... im gonna make some calls
[Re: off-roader]
#708742
03/22/06 07:27 PM
That bindex hose is a good bit longer then stock I guess?
I think im just gonna take the shocks loose and the hose off drop the rear end and do it that way, then have the compressors as a back up. Im thinking bleeding the system is less evil then those stinkin spring compressors....
[Re: off-roader]
#708744
03/23/06 02:10 AM
Is the longer hose the same part number for the SWB? I am glad this topic came up. I forgot I could stand to change it for a longer one.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT gen 2 coils,Cranked front tbars Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
[Re: Tag]
#708745
03/23/06 02:25 AM
dang.. I just replaced mine. Dont tell me i goto do it all over again when i lift it. I never thaught those compressors where so bad. Just need to take your time.
