V6 radiator fit in 4 Cyl 89 Trooper? #708819 03/22/06 04:04 AM
japanese_jag Offline OP
Anybody know if I can just drop in the V6 radiator in my 89 4 cyl auto trooper without modifications? Does my 4 cyl shroud make up to the V6 radiator? The trooper has AC and stock fan. It appears as if the radiator support is the same for both V6 and 4? Thanks
Re: V6 radiator fit in 4 Cyl 89 Trooper? [Re: japanese_jag] #708820 03/22/06 06:56 AM
Ed Mc Offline
I pulled an almost-new radiator out of a scrapper '89 2.6 LS and it dropped right into my '89 'stroker' V6 Troop.
Since your 2.6 is bolted up to an automatic, you'd want to make sure the V6 radiator has the built-in auto tranny cooler at the bottom.
HTH.........ed
'90 Troop 3.4 LS
'89 Troop RS (Has Valve Issues, needs Counseling)
HI, I'm Ed and I'm a Trooper-holic!
Keep On Troopin'......
Re: V6 radiator fit in 4 Cyl 89 Trooper? [Re: japanese_jag] #708821 03/26/06 06:35 PM
Trooper-san Offline
I have one of each, a 2.6 and a 2.8, both '89. The 2.8 has a/c, the 2.6 does not. I've switched the radiators back and forth (don't ask) to the point where I'm not sure now which was original in which vehicle. You should have no problem. As Ed said, check for cooling if you have an automatic.
1989 Trooper, 2.6
1989 Trooper, 2.8
1992 Ford F-350, 7.3
My Photos
PHP: 7.4.33 Page Time: 3.748s Queries: 15 (0.003s) Memory: 0.5924 MB (Peak: 0.6454 MB) Data Comp: Off Server Time: 2026-06-13 10:06:59 UTC
