Is there a trick to loosening the tensioner pulley? #709034 03/23/06 01:27 AM
Nix_Toy Offline OP
Hey guys.. I'm trying to put all my belts on, but the tensioner pulley for the A/C is not budging. I've tried loosening the bolt a little, then hitting it with a hammer.. but the darn thing still won't budge. Any ideas on how to move it?
Thanks
-Nick
Re: Is there a trick to loosening the tensioner pulley? [Re: Nix_Toy] #709035 03/23/06 01:36 AM
Talon84X4 Offline
bigger hammer <img src="/forums/images/graemlins/kewl.gif" alt="" />
'84 PU low & slow
Central Valley Crawlers
Re: Is there a trick to loosening the tensioner pulley? [Re: Nix_Toy] #709036 03/23/06 02:14 AM
yodta Offline
you have to loosen the nut in the center of the pulley.
then the adjusting bolt will screw in or out with ease.
bigger hammer... bah!
heheheh
msg - '87 xtracab
Re: Is there a trick to loosening the tensioner pulley? [Re: yodta] #709037 03/23/06 03:13 AM
RatLabGuy Offline
Agreed.
It took me 45 minutes of profanity to figure that out <img src="/forums/images/graemlins/scared.gif" alt="" />
Question Reality.
Re: Is there a trick to loosening the tensioner pulley? [Re: yodta] #709038 03/23/06 03:18 AM
Nix_Toy Offline OP
heheheh
Hmm.. didnt' think of that.. I'll try that tmorrow when there's light outside again.. thanks guys!
Re: Is there a trick to loosening the tensioner pulley? [Re: Nix_Toy] #709039 03/23/06 03:33 AM
Happy Birthday 87Toy4x4 Offline
when you tighten the nut back up, dont crank on it or else youll burn the bearing.
Re: Is there a trick to loosening the tensioner pulley? [Re: 87Toy4x4] #709040 03/23/06 03:36 AM
yodta Offline
I thought there was a bushing or special washer that prevented that, actually. can't remember offhand...
msg - '87 xtracab
Re: Is there a trick to loosening the tensioner pulley? [Re: yodta] #709041 03/23/06 06:12 AM
Talon84X4 Offline
second the over tightening, yes there'ss a small bushing that should prevent it, but it doesn't do a very good job, if you clean it up as well it should prevent it from seizing up while being able to tighten it up reasonably....if it's dirty that is
'84 PU low & slow
Re: Is there a trick to loosening the tensioner pulley? [Re: Talon84X4] #709042 03/23/06 03:17 PM
TimsToyo Offline
Use some bearing grease on the bushing, bolt, and the bearing. You might as well grease it while you have it loose.
'86 Toyo 4wd
'04 600RR
Re: Is there a trick to loosening the tensioner pulley? [Re: Talon84X4] #709043 03/23/06 04:29 PM
Brown Offline
Not sure if I overtightened mine since it's been about 2 years since I touched it, but it locked up on me this morning on the way to work. At least I was almost here by the time it happened, but man that belt was a smokin'! <img src="/forums/images/graemlins/shiner.gif" alt="" />
Jeremy
SOLD:[color:"666666"]1988 Toyota 4x4 | 22RE | W56 | EB 270 cam [/color]
PHP: 7.4.33 Page Time: 2.332s Queries: 15 (0.003s) Memory: 0.6295 MB (Peak: 0.7203 MB) Data Comp: Off Server Time: 2026-05-29 16:39:21 UTC
