FJ80 rod ends? #709080 03/23/06 02:41 AM
lethe Offline OP
my question is will the FJ80 tie rod ends that marlin sells fit a stock tie rod from an 84' pickup? it says that they are used on cross over set ups on pickups and 4-runners, but it also says that the threads are up to 6mm larger in diameter then stock. does this mean you have to order one of their tie rods to use these ends or will they fit a stock tie rod? i would e-mail marlin directly but for some reason my computer wont let me.
thanks,
jared
87' ext cab toy
Re: FJ80 rod ends? [Re: lethe] #709081 03/23/06 02:43 AM
DirtyHarry Offline
Toyota Moderator
They will not fit the stock tie rod, they are larger. You will need to order stock replacements or get a new tie rod.
Re: FJ80 rod ends? [Re: DirtyHarry] #709082 03/23/06 03:00 AM
lethe Offline OP
where can you order stock replacements from? thanks for the quick reply
87' ext cab toy
Re: FJ80 rod ends? [Re: lethe] #709083 03/23/06 03:10 AM
lethe Offline OP
nevermind, napa has em' for $32
87' ext cab toy
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.5989 MB (Peak: 0.6545 MB) Data Comp: Off Server Time: 2026-10-24 23:59:55 UTC
