Page 1 of 4 1 2 3 4
In need of more power on the highways... #709628 03/24/06 08:27 PM
DRTDEVL Offline OP
Well, I have finally realized that the 22RE is not quite up to the task just yet here on the Autobahns... I can cruise comfortably at 80 (as long as there is no headwind), but as soon as I hit the slightest grade or headwind, the poor hamsters get tired. I am looking for ideas to free up more power.
Here's what I run:
22-RE
0.040" overbore
EB SS Pistons
EB SS/OS valves
EB 270/430 cam
EB H/V Oil pump
EB Steel rail timing set
EB Water pump
Intake gasket-matched
2.25" exhaust, Flowmaster 50 series
K&N drop-in filter
Denso plugs/wires, OEM cap/rotor
Redline synthetic oils in transmission, transfer, and diffs.
I also dropped down to 31's before bringing the rig here.
What else can I do? Would an MSD-6A help? I know I can bump my timing up and run premium, but with the cost of fuel over here, it's not really an option ($2.64 for 86 octane, $2.79 for 88, and $2.99 for 91 *on base*).
Who has any ideas? EB?
BTW: It needs to remain a reliable DD while here... I am not looking to go 200 mph, just to not get run over when passing a semi.
TIA <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: In need of more power on the highways... [Re: DRTDEVL] #709629 03/24/06 08:32 PM
Gearing?
Re: In need of more power on the highways... #709630 03/24/06 08:35 PM
DRTDEVL Offline OP
Oops!
4.10:1, stock.
Re: In need of more power on the highways... [Re: DRTDEVL] #709631 03/24/06 08:39 PM
Find some 4:88's out of a junkyard... At the very most they'll be 200$ a diff.
Re: In need of more power on the highways... #709632 03/24/06 08:41 PM
DRTDEVL Offline OP
4.88:1 combined with the W56 trans will wind out too fast on 31's. 4.56:1 would be ideal, yet still wind up above 80.
I need top speed here. My accelleration is fine (I can burn tires if need be), but I run out of breath against the stiff headwinds here.
Re: In need of more power on the highways... [Re: DRTDEVL] #709633 03/24/06 08:47 PM
I was looking at your sig. **33's my bad
Re: In need of more power on the highways... #709634 03/24/06 08:49 PM
DRTDEVL Offline OP
Yeah... I dropped down right before coming here due to very strict modification laws. I still have my 33's for whenever I join an eastern european (or scandinavian) wheeling expedition.
Re: In need of more power on the highways... [Re: DRTDEVL] #709635 03/24/06 09:16 PM
4Crawler Offline
4.56 gears would be a good investment and would give you the biggest bang for the buck w/ 31s.
A bored out throttle body can help, maybe the larger AFM, too.
Also, at 80+, aerodynamics can help big time, a wind deflector in the rear and maybe one on the hood and if you have the front lifted w/ torsion bars, consider dropping it down an inch or two.
Re: In need of more power on the highways... [Re: 4Crawler] #709636 03/24/06 09:41 PM
Is it a bored out throtthle body or plenum that would help?
Re: In need of more power on the highways... [Re: 4Crawler] #709637 03/24/06 09:50 PM
DRTDEVL Offline OP
AFM searching will be highly difficult over here... Most Toyotas were diesel (lucky dogs).
I though about lowering the front, but I don't want to look too goofy going down the road like that.
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6362 MB (Peak: 0.7576 MB) Data Comp: Off Server Time: 2026-06-09 16:37:37 UTC
