changing the carter bbd to something else #709766 03/25/06 03:51 AM
G
Greg2000 Offline OP
I have a cj7 with very low miles but the carter bbd is giving me a lot of problems. I would like to replace it with a carb without the computer assit. First, is this possible? Second, what are some of your reccomendations for replacement carbs? I have seen a conversion kit for a fomoco 2100 is this a good replacement?
Re: changing the carter bbd to something else [Re: Greg2000] #709767 03/25/06 06:04 AM
BigJim Offline
Howdy Greg The computer also controls the dist.. If you put a different carb on there the dist will give you fits! I would first make huge attempts at fixing the carb. ANYTHING you do to the carb will require substantial dist changes.
Re: changing the carter bbd to something else [Re: Greg2000] #709768 03/27/06 12:57 AM
Do an H.E.I. dist. conversion, an a 2100 carb exchange, about $400 , an forget about it, the best money you will ever spend on that tub.
Re: changing the carter bbd to something else [Re: Greg2000] #709769 03/27/06 08:01 PM
I have a BBD and it's great. <img src="/forums/images/graemlins/nana.gif" alt="" />Non-computer controlled. 1/2 a can of crab cleaner every 6 months and it's been great for 3+ years.
PHP: 7.4.33 Page Time: 3.470s Queries: 15 (0.009s) Memory: 0.5925 MB (Peak: 0.6517 MB) Data Comp: Off Server Time: 2026-07-16 06:54:39 UTC
