Re: Are these cracks in head OK? [Re: Paul223] #710362 04/05/06 02:11 AM
JLEMOND Offline
PAUL I HAVEN,T FORGOT YOU ON THE LOCK IN STITCH, I GO THE ADDRESS AND LAID IT ONMY WORKBENCH AND NOW I CAN,T FIND IT , WILL CLEAN THE TABLE TOMORROW AND GET THE ADDRESS AND THE PH NO JERRY
Re: Are these cracks in head OK? [Re: JLEMOND] #710363 04/05/06 03:20 AM
Paul223 Offline OP
Jerry--
OK, I am in no great hurry. This project will be taking me a long time.
Thanks --
Paul
Re: Are these cracks in head OK? [Re: Paul223] #710364 04/06/06 12:47 AM
JLEMOND Offline
HEY PAUL GOT THE INFO ON THE CAST IRON REPAIR KITS , LOWER CASE ON THE ADDRESS,
www.LOCKNSTITCH.COM 1-800-736-8261,THIS CO, CAME TO OUR TRAINING CENTER YEARS AGO AND DID A 2 DAY TRAINING SESSION ON THEIR STUFF AND IT IS VERY IMPRESSIVE , THEY ALL SO HAVE SOME OF THE BEST THREAD INSEARTS YOU HAVE EVER SEEN , AND THEY WON,T COME OUT IF INSTALLED CORRECTLY GIVE EM A BUZZ
JERRY THEY ARE IN TURLOCK CA, SO THEY ARE FAIRLY CLOSE .
Re: Are these cracks in head OK? [Re: JLEMOND] #710365 04/06/06 06:57 AM
Paul223 Offline OP
Jerry--
Gotcha on the LocknStitch. I will check them out. Thanks for the legwork and recommendation.
Paul
Re: Are these cracks in head OK? [Re: Paul223] #710366 04/07/06 02:02 AM
JLEMOND Offline
HEY PAUL I HAVE TO RECCOMMEND THAT STUFF ,IT IS GREAT, ONCE YOU LEARN TO USE IT CORRECTLY YOU CAN REPAIR A CAST IRON CRACK AND IT IS ABSOLUTELY STRONGER THAN THE PARENT METAL AND ALLMOST IMPOSSIABLE TO TELL IT HAS BEEN REPAIRED , IT IS A LITTLE TIME CONSUMING TO USE THE TOOLS , BUT IS CAN SAVE A TON OF MONEY , I USED TO HAVE A FRIEND CLOSE BY HER WHO REPAIRED A CRACK IN AN OLD MASEEY FERGUSON TRACTOR BLOCK AND IT TOOK HIM ABOUT 4 HRS TO DO THE WHOLE CRACK BUT WHEN HE GOT THRU IT WAS PERFECT , THE BLOCK WAS JUST UNOBTAINALBE AT THE TIME ,, I MENTIONED HE WAS A FRIEND HE PASSED AWAY 3-4 YRS AGO AN AUTOMOTIVE MACHINEST TO END ALL BUT HE LET THE WHISKEY DO HIM IN AT 52 YRS OLD .. JERRY
Re: Are these cracks in head OK? [Re: JLEMOND] #710367 04/09/06 06:01 AM
Paul223 Offline OP
Jerry--
Way too bad about your machinist friend. Thanks for the testimonial and info on the LocknStitch. I will look into getting a Kit.
Paul
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6128 MB (Peak: 0.6826 MB) Data Comp: Off Server Time: 2026-06-07 06:28:03 UTC
