Re: Dead random miss... [Re: BigJim] #711330 04/11/06 09:35 PM
W
wyleone Offline OP
Did the Nutter today and [Linked Image]
It worked awesome!!!!!!
My timing only changed 4degrees retarded so I set it at 8BTDC.
Also the "orange" wire from the ECU to the ign module was light green w/ black tracer. The orange and purple from the distributor to the ECU were a twisted pair to help trace. That is in an 87 YJ w/ 4.2L. <img src="/forums/images/graemlins/smile.gif" alt="" /> No more pinging!!!!!!!!!!!
Re: Dead random miss... [Re: wyleone] #711331 04/11/06 09:43 PM
JeePete Offline
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Dead random miss... [Re: JeePete] #711332 04/12/06 02:37 AM
W
wyleone Offline OP
No more hesitation, no more cutting out, smooth idle. That darn ECU had this thing doing backflips.
Re: Dead random miss... [Re: wyleone] #711333 04/12/06 02:44 AM
BigJim Offline
Wyle I always cut the ecu wires on the ecu side of the plug.. If you look at that plug there are more wires coming OUT of the plug than there are going in from the ecu.. So I cut the purple and orange wire and wire from there.
Re: Dead random miss... [Re: wyleone] #711334 04/12/06 02:46 AM
JeePete Offline
Far out! Sent you a PM. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Dead random miss... [Re: BigJim] #711335 04/12/06 02:49 AM
W
wyleone Offline OP
The main harness right behind the carb had severe fire damage at one point and I had alot of repair work that i did when I bought it. So it was not a big deal to me. When I get around to swapping in a 4.0L (not a high priority right now) it will get a new harness anyway.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6133 MB (Peak: 0.6992 MB) Data Comp: Off Server Time: 2026-06-19 23:53:49 UTC
