Re: Help with P0326 Knock Sensor [Re: LiorB] #711452 02/11/11 06:17 PM
logansportage Offline
The knock sensor is going off because of extra noise coming from the backlash in the valves. It's a common problem for the Sportage. Typically you just need to adjust the backlash on the valves so there is less knock. Not a very hard problem to fix, but it will return over time. It's a known issue that KIA has no fix for other than continuing to adjust it until you are out of warranty. Then you just get to deal with it, adjust it on your own, or pay them to adjust it. It has no ill effects on performance, just over time it makes a ticking noise until the engine gets warm. Then it goes away. However, the code does not and your little light stays on all the time.
Re: Help with P0326 Knock Sensor [Re: logansportage] #711453 02/12/11 12:43 PM
L
LiorB Offline
Thanks for the explanation Logan.
Can you please direct to the instructions how to adjust backlash in the valves?
Is there information about it in the service info at Kia tech info?
Thanks,
Lior
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5947 MB (Peak: 0.6432 MB) Data Comp: Off Server Time: 2026-06-07 11:34:24 UTC
