Pull under braking
#711642
03/31/06 09:50 PM
Every time I go to brake my 95 4runner pulls HARD to right. The alignment is good and goes straight at a constant speed. It has a slight pull to the left under accelleration too. Steering feel is just bad in general. Im thinking there are some shot bushings. Is this possible? which bushings would be shot
1995 4runner SR5 PP rear springs Hella FF1000 lights 31X10.5-15 Nokian Vativas <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Pull under braking
[Re: Davis5210]
#711643
04/01/06 01:17 AM
Well, for the braking.. there could be a couple factors. Your caliper can be sticking on the left side. Also, check to make sure your rotor hasn't separated from the hub on the left side... it can happen, 'cause I've done it!
[Re: Nix_Toy]
#711644
04/01/06 04:06 AM
Brake fluid on the pads will make it pull hard to one side also. Check for a leaking wheel cylinder.
Have you pulled the hub and looked at the pads?
'86 Toyo 4wd '04 600RR
[Re: TimsToyo]
#711645
04/01/06 04:45 PM
yeay, inspect the rotors for contamination first, throw some brake cleaner on them and then...
I 2nd what Nick said...
I had a bad caliper on mine that did the same thing. this is why it's good to flush your brake fluid periodically -- those parts can get corroded and stop moving freely even though they might still look good.
msg - '87 xtracab
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6001 MB (Peak: 0.6556 MB) Data Comp: Off Server Time: 2026-06-23 09:48:50 UTCValid HTML 5 and Valid CSS
