Re: progress pics #711794 04/03/06 03:18 PM
Boertjie Offline
If that is a turbo engine, if will have no guts (without the turbo), due to the low compression?
1989 Exceed LWB
4m41 (3.2DiD TurboDiesel
5-spd Manual Tranny
2" lift
31" BFG A/T
Re: progress pics [Re: Boertjie] #711795 04/03/06 04:53 PM
G
grifter679 Offline OP
my dad did some research and the new motor is out of a front wheel drive vehicle chances are then compression ratio will be 10:1 , the stock montero 3.0 is according to his research 8.5:1, im hoping this is all true.
as far as the turbo on a sohc mitsubishi never made one from the factory, i think there are kits for a turbo to be put on the sohc, the (t) that the guys put on valve cover is my guess to what they were doing
Re: progress pics [Re: grifter679] #711796 04/03/06 05:05 PM
Don't forget though a car motor will also be set up for more HP and less torque which isn't such a good idea in a 4x4, unless you only plan on using it to commute. From what I understand, start and stop traffic will be much tougher w/out the torque.
Re: progress pics [Re: off-roader] #711797 04/04/06 07:27 AM
Boertjie Offline
It could be that the (t) is for "Transverse" mounted as opposed to "Longitudinally" mounted?
1989 Exceed LWB
5-spd Manual Tranny
2" lift
31" BFG A/T
Re: progress pics [Re: Boertjie] #711798 04/04/06 07:33 AM
G
youre probably right with that, i was thinking the same then sort of let the idea sit
Re: progress pics [Re: grifter679] #711799 06/01/06 10:24 PM
So how is this going?
my brothers has 220,000 miles and we have been trying to keep the cost of a replacement moter in the back of the old mind.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6140 MB (Peak: 0.6843 MB) Data Comp: Off Server Time: 2026-06-20 18:33:39 UTC
