PTO Winch Question. #712063 04/02/06 02:08 PM
O
ojo1 Offline OP
do the PTO winchs on the Pajeros use oil?
Bought a second hand one recently, looks like it has a drain plug but unsure.
Any ideas on the type of oil if it does - is it the same as the diff or gearbox?
Thanks in advance
Re: PTO Winch Question. [Re: ojo1] #712064 04/03/06 03:57 AM
The pto gears mesh with the transfer case gears, so I guess they share the same lube.
Re: PTO Winch Question. [Re: fasteddy] #712065 04/04/06 12:38 AM
PartyTruck Offline
If your'e meaning the winch itself it probably just uses gear oil.
[hijack] Has anyone here any info on the PTO's if they fit between Gen's. Can I take a PTO from a Gen 1 and fit it on my Gen 2 ? [/hijack]
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
Re: PTO Winch Question. [Re: ojo1] #712066 04/04/06 06:34 PM
L
Lester Offline
We use gear oil mix with general grease. (1:1 ratio)
PHP: 7.4.33 Page Time: 1.357s Queries: 15 (0.004s) Memory: 0.6000 MB (Peak: 0.6556 MB) Data Comp: Off Server Time: 2026-06-17 00:58:00 UTC
