Re: 91 Toyota o2 sensor replacement [Re: 4WD22R] #712260 04/05/06 07:51 AM
kewlynx Offline
So did you get that hot dog cooker yet?
**ubi apis- ibi salus**
Re: 91 Toyota o2 sensor replacement [Re: kewlynx] #712261 04/05/06 07:53 AM
4WD22R Offline
the '85? naw, in about a month(I think) the owner is a bit loopy. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: 91 Toyota o2 sensor replacement [Re: 4WD22R] #712262 04/05/06 12:31 PM
Thanks for the posts!!
I just ordered a manual from Amazon.com and now maybe I'll have something to refer to.
I'll also check the wiring harness and see if I can find the wires.... the posts I've read say there should be two one before the cat and one after... I'll be getting them and putting them on.
I'm hoping this will make Leroy Duece feel and run better...
Thanks again!!! I'll provide updates as I proceed.
NJ
<img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: 91 Toyota o2 sensor replacement #712263 04/05/06 04:18 PM
1
1986xtracab Offline
I dont think there is one after the cat. OBD II vehicles have that.
Re: 91 Toyota o2 sensor replacement [Re: 4WD22R] #712264 04/09/06 03:46 AM
Ok... I found the sensor this evening and I soaked in WD 40 and I've ordered a new sensor. I hope this will help.
Right now the motor surges at idle and the idle is fast. I have the top off the air controller and it is rotating to a position which causes the engine to run a bit fast. I can smell a bit of gasoline when it is running so I know it is running rich. Also only getting around 14 mpg... I hope this o2 sensor helps.
If you have any other ideas, please post.
Thanks
NJ
Re: 91 Toyota o2 sensor replacement #712265 04/09/06 04:10 AM
kewlynx Offline
Remember to pull your EFI fuse by the driver's kickpanel for about 10 sec to clear any codes. The ECU will recalibrate its loop with the new sensor. Check out the emissions tech articles at www.autoshop101.com on this subject.
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6146 MB (Peak: 0.6966 MB) Data Comp: Off Server Time: 2026-07-16 12:38:52 UTC
