Page 1 of 4 1 2 3 4
3.5 v6 /mpg`s #712800 04/04/06 08:34 PM
KB2IAW Offline OP
I was wondering what kind of MPG you guys get on you 3.5 montero`s i am averaging 16 mpg highway under 60 MPH in cruise control,(some hills) in town about about 13 MPG ,i have never tried to average gas milage on trails .what are you getting in the way of gas millage,also using lower octaine87%..would a higher octaine get more power and MPG ??? <img src="/forums/images/graemlins/confused.gif" alt="" />
MPG /vs /OCTAINE
multiple choice, up to 2 choices
mpg (0%, 0 Votes)
octaine (0%, 0 Votes)
No Votes Yet
Voting on this poll ends: 04/04/06 07:33 PM
1994 montero SR 3.5 v6
City Of Hills Oneonta N.Y. FREEDOM HAS A TASTE,AND FOR THOSE THAT HAVE FOUGHT FOR IT, THE TASTE IS SO SWEET , THE PROTECTED WILL NEVER KNOW .
VENI VEDI DECI <oneontasportsmenclub.net>
Re: 3.5 v6 /mpg`s [Re: KB2IAW] #712801 04/04/06 11:05 PM
IIRC you are supposed to use premium fuel with the 3.5, also, IIRC, no you don't get better mileage with higher octane fuel. Just less knocking... but perhaps someone more knowledgeable can elaborate on this.
Re: 3.5 v6 /mpg`s [Re: KB2IAW] #712802 04/04/06 11:29 PM
LRJ4x4 Offline
Octane is a anti-knock additive for high compression engines. It has very little to do with MPG. Use whatever gas is recommended in the owners manual. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 3.5 v6 /mpg`s [Re: KB2IAW] #712803 04/05/06 06:43 AM
I
Indikka Offline
... Ummm ... not good.
The V6 is said to be better than V4.
Most of us don't have working gas gauges, ... for the better.
Regards,
Robert Nesta
Re: 3.5 v6 /mpg`s [Re: Indikka] #712804 04/05/06 09:27 AM
Your MPG seems a little bit low. I monitored mine for 3 years and averaged 19MPG on long, highway journeys and 14MPG on my daily commute (I-395 into DC). Ref octane rating I used all grades of fuel and didn't get any noticeable changes in MPG, performance or knock. Handbook recommends premium gas, so I used that nearly all the time.
By the way, I'm in UK now and gas prices here are about $6.20 per gallon!! What we all need is an Raider/Montero/Pajero electric motor conversion <img src="/forums/images/graemlins/ignore.gif" alt="" />
Re: 3.5 v6 /mpg`s #712805 04/05/06 03:21 PM
DougH Offline
Mitsubishi Forum Moderator
Not sure what it is but once I put the 33's on it became awful. I am only getting about 250 miles out of a full tank.
It doesn't help that I am allways on the gas though. If I babied it I might get some better gas mileage. <img src="/forums/images/graemlins/frown.gif" alt="" />
DougH
1995 SR - RIP
1993 RS - RIP
Re: 3.5 v6 /mpg`s [Re: KB2IAW] #712806 04/05/06 06:52 PM
cap510 Offline
The last time I check I got 13.5 MPG on combine miles <img src="/forums/images/graemlins/scared.gif" alt="" />
Rack + lift + big tires = bad MPG <img src="/forums/images/graemlins/smile.gif" alt="" />
[b]94/95 Montero SR "rockcrawler"
Riding on 37" MTRs
Re: 3.5 v6 /mpg`s [Re: DougH] #712807 04/05/06 07:59 PM
Doug, don't forget to factor in the reduction in gearing therefore the reduction in the odometer mileage as well. IIRC there's a 12-13% difference in size from the stock tire to the 33" tire. This means you're actually travelling 113 miles for every 100 miles on your odometer unless you've changed out the speedometer gear in the xcase.
I'd check your speed using a GPS then factor the difference into your mileage calculations. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 3.5 v6 /mpg`s [Re: off-roader] #712808 04/05/06 08:28 PM
DougH Offline
I did. 230 miles to the tank if I don't add in the 10% or so increase. The truck originally had 31's as far as I know.
DougH
1995 SR - RIP
1993 RS - RIP
Re: 3.5 v6 /mpg`s [Re: DougH] #712809 04/05/06 08:51 PM
Chris_J Offline
I get about 120-130 to the tank with my 2.6 30inch mud rovers. It sucks. Thats why I want to sell it. Any offers?
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 2.418s Queries: 21 (0.004s) Memory: 0.6519 MB (Peak: 0.8395 MB) Data Comp: Off Server Time: 2026-06-19 12:26:44 UTC
