Winches - Advise on Winch purchase #713129 04/05/06 05:14 PM
Tommytuttle Offline OP
Friend of mine is selling a Warn« M8274-50 8000 lb Winch with Roller Fairlead.
Any advise on this winch? I'm trying to do some research, if memory serves me correct this is a military style winch which is very robust, but how does it compare to new ones.
Costco also has a "Champion" 8000lbs... anyone know about this.
On the weekend I bought a 2000lbs winch which came with a receiver type set up.. which I thought would be ok on the rear hitch in a real pinch with a pully block to double the strength.
I suppose mounting the warn on my 20004runner would be pain, but I have an 81 pickup it would be good for.
Any advise would be appreciated
Tom P
2000 4runner 5spd SR5 (pretty much stock) Bridgstone REVO(275/70r16)
Re: Winches - Advise on Winch purchase [Re: Tommytuttle] #713130 04/05/06 05:29 PM
This is THE WINCH! Not the strongest, but for an 8000lbs winch, this is the marker that all others are judged by. The gearing is different which allows for the extremely fast line speed. The only issue, is that this winch is large and eats up a ton of grill space.
My theory for winches is this, buy something that is bigger than what you will need and be patient. Unless you are running in some sort of timed competition, then speed is ususlly not a factor. Do not stall the winch and bind it. If the load is not moving, you are burning up the motor.
All winches are made basically the same, with the same motor (starter motor) and same planetary gearing. However, the Warn 8274 is different in its gearing, allowing for the legendary strength, speed and durability. The 8274 will break, it is not bullet proof. But, if you can get a good deal on one, go for it. The main reason I don't have one is I cannot justify $1200 for a winch that may get used 1 or 2 times a year.
Good choice for a winch though.
Thanks,
James
Re: Winches - Advise on Winch purchase #713131 04/05/06 06:27 PM
Thanks James.
So for the $200 CND I should buy it.
yeah... not sure how it will install.
Tom P
PHP: 7.4.33 Page Time: 0.231s Queries: 15 (0.004s) Memory: 0.5910 MB (Peak: 0.6454 MB) Data Comp: Off Server Time: 2026-06-17 13:37:26 UTC
