1988 trooper black thing???? #713557 04/06/06 04:27 PM
tobeornottobe Offline OP
hi can any one tell me what the black electrical component is on the hose coming off air filter?? it has an arrow on it..it is pointing to me in the wrong direction..against air flow..all other arrows on air system point other way(with air flow)..Is this a concern or is it correct? and what the heck is it? all places i went dont have any manuals....
Re: 1988 trooper black thing???? [Re: tobeornottobe] #713558 04/06/06 04:38 PM
Richard Saylor Offline
Sounds like you're talking about the MAF sensor. But I'm not sure. But I would say that if it's got an arrow on it, it should be pointing towards the engine.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: 1988 trooper black thing???? [Re: Richard Saylor] #713559 04/06/06 05:06 PM
CPOM Offline
what engine
CHRIS
98 Amigo, 92 Pup
Re: 1988 trooper black thing???? [Re: CPOM] #713560 04/06/06 06:00 PM
88 Trooper would have to be the 2.6 since it wasn't until 89 that they put the 2.8 in. And I don't believe they had the 2.3 that year, just the 2.6 but I could be wrong.
84 Honda XL185S
Re: 1988 trooper black thing???? [Re: tobeornottobe] #713561 04/06/06 11:24 PM
Troopersphere Offline
If it's right next to the air filter, and it says HITACHI on it, then the arrow points AWAY from the engine, TOWARD the air filter. It is the Mass Air Flow sensor. I doubt the engine would be running if it were installed backward.
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
Re: 1988 trooper black thing???? [Re: Troopersphere] #713562 04/07/06 12:39 AM
I
Idaho_Trooper Offline
No 2.3, just 2.6.....
James "MOZES" Tester
1988 Trooper SAS
Re: 1988 trooper black thing???? [Re: Idaho_Trooper] #713563 04/07/06 02:15 AM
JLEMOND Offline
RICHARD IS CORRECT ONLY THE 2.6 AFTER SEPT 87 PRODUCTION, AND JEFF IS CORRECT ALSO ABOUT THE MAF SENSOR , I DIDN,T THINK YOU COULD INSTALL THAT THING BACKWARD THE WAY IT BOLTS UP,I WAS THNKING AGAIN , ISN,T THE HOSE CONNECTION LARGER ON ONE SIDE THAN THE OTHER . JERRY
Re: 1988 trooper black thing???? [Re: Troopersphere] #713564 04/07/06 05:00 PM
ok great yes it says hitachi...thank u guess its right then...just kind of made me wonder..thank u..do u know if u can reset computer any other way besides dissconnect battery..changed o2 sensor but light on dash still on..?????? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: 1988 trooper black thing???? [Re: tobeornottobe] #713565 04/07/06 06:25 PM
Jim_Paget Offline
If you are talking about the O2 sensor light on the dash, it comes on every 90,000 miles to remind you to change the sensor. There is a switch on the back of the instrument cluster that needs to be moved to the opposite position of where it is now.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: 1988 trooper black thing???? [Re: Jim_Paget] #713566 04/07/06 10:15 PM
Just to elaborate on Jim's explanation a bit...
Get a flashlight or a drop light, and on your back, stick yer head under the dash on the driver side. Look at the back of the speedo pod, you should be able to see a small square black "slide" switch. As Jim said, move it to the opposite position. That's all there is to it for another 90K miles.
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6407 MB (Peak: 0.7596 MB) Data Comp: Off Server Time: 2026-11-17 04:49:57 UTC
