Re: carter fuel pump issues [Re: 87Toy4x4] #713650 04/08/06 02:06 AM
yodta Offline
are you guys running oil pressure switch relays to your pumps so that if the engine dies the pump cuts off?
otherwise, what do you to cut of the fuel flow until the engine is actually running? what if your engine dies with the ignition switch on? isn't it still pumping fuel into your carb?
msg - '87 xtracab
Re: carter fuel pump issues [Re: yodta] #713651 04/08/06 03:13 AM
dewmtndew Offline OP
Well Its been working all day, and I drove around quite a bit. Ive still got my figers crossed that it is fixing itself.
what gauge wire are you running to it. it might be starved for power. check to see if you have a good ground also
I was thinking about getting some thicker wire for it. Its 14 I think, maybe 16 gauge wire. Ive checked the ground, it is grounded where the fuel pump bolts on so that is pretty secure.
I was going to ge one of those, but then I could only find one on summit and didnt feel like dropping $20 on it. I got a switch in the cab instead. It doubles as a kill switch too. I just had to get in the habit of turning it on and off, Ive never had trouble leaving it on, its pretty loud.
erick
85 Pickup
33s, lift, EB cam, header, exhaust...
Re: carter fuel pump issues [Re: yodta] #713652 04/08/06 09:26 AM
4WD22R Offline
Mine is only on there to 'suppliment' the stock mechanical pump, at least this is what I was told, the PO installed it.....near as I can tell, it's got a pressure regulator on it, you can hear it if you turn the key to 'ON' it runs for a sec and then turns off, you never hear it again unless I get at some crazy angles, where the carb would normaly start to sputter and then it kicks in.
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: carter fuel pump issues [Re: 4WD22R] #713653 04/08/06 02:57 PM
yodta Offline
I've never heard of anyone running two fuel pumps.
can you explain how this works?
how does the stock one stop working at extreme angles?
seems to me like running two fuel pumps would push too much fuel to the carb, or are you saying they both don't run at the same time?
msg - '87 xtracab
Re: carter fuel pump issues [Re: yodta] #713654 04/09/06 02:09 AM
4WD22R Offline
to tell you the truth, I really don't know, it was on there when I got it and that's how it was explained to me....I know the factory pump still works, and the other one only comes on at extreme angles, well that's when I can hear it, or when my fuel filter starts getting clogged. Near as I can tell, it's pressure regulator is set so it turns on when the fuel pressure drops below whatever the factory pump runs at....but I'm still at a loss as to how, or why it works <img src="/forums/images/graemlins/confused.gif" alt="" /> but I can tell you, it dosen't have as much trouble when you start gettin tippy as my buddies carbed '85 does......
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
--George W. Bush
Re: carter fuel pump issues [Re: 4WD22R] #713655 04/09/06 03:25 AM
yodta Offline
hmm.
interesting.
I've almost put on an electric pump a couple of times, but not yet... got too many unanswered questions smile
msg - '87 xtracab
Re: carter fuel pump issues [Re: yodta] #713656 04/09/06 04:55 AM
I was in the same position, I did quite a bit of reading about the pros and cons before installing. At first the sound was kind of annoying but now its comforting...one more thing I know is working. With my weber its really nice to have the electric because of the rotary style it is. It pumps fuel consistently where the stock pump sends fuel in bursts. My engine smoothed out a bit and seemed a bit more responsive.
erick
85 Pickup
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6272 MB (Peak: 0.7190 MB) Data Comp: Off Server Time: 2026-05-29 15:27:41 UTC
