Water pump for 2.6 #713735 04/07/06 01:14 AM
Z
zKnightWhoSaysNi Offline OP
Is there a high flow water pump available for the 2.6? I've looked and searched without finding anything. what is the best recommended brand water pump that you all are using?
'99 Trooper, 912's
'89 Trooper RS, 2.6
Re: Water pump for 2.6 [Re: zKnightWhoSaysNi] #713736 04/07/06 02:11 AM
JLEMOND Offline
IF YOUR RAD IS IN GOOD SHAPE WHY WOULD YOU WANT A HI FLOW WTR PUMP, THE FACTORY PUMP IS PROB ABOUT THE BEST YOU CAN BUY , HOWEVER THEY WILL ONLY RUN AROUND 200.000 MI, JERRY
Re: Water pump for 2.6 [Re: JLEMOND] #713737 04/07/06 06:16 AM
Z
As I get the engine running again, and replace parts related to cooling system that need replacing or are suspect in performance, I want to make upgrades if possible. I want to be as sure as possible of preventing any future overheating problems. Thanks for the input!
'99 Trooper, 912's
'89 Trooper RS, 2.6
PHP: 7.4.33 Page Time: 6.233s Queries: 15 (0.003s) Memory: 0.5916 MB (Peak: 0.6445 MB) Data Comp: Off Server Time: 2026-06-11 14:11:14 UTC
