Re: Can you get this certain size tire? [Re: turboDIESELtrooper] #714221 04/21/06 04:07 PM
Alright, thanks again for the info and help. I appreciate it. The 33x9.5x15" tire is what I wanted to go with originally, but after a 2-2.5" suspension lift some people were saying it may be somewhat unstable and have the possibility of rolling given the tire is tall and narrow. I don't think it's that big of an issue, do you? I wanna try to keep running the original 15x6" rims that came factory on the 86, so in turn that will be a wide enough rim for the 33x9.5x15" tire I think.
Well, you want to keep your rims so this might not be any help, but I bought rims with more offset so the tires stick out more. Keeps the frame rubbing down and widens the wheel base just a touch.
Re: Can you get this certain size tire? [Re: turboDIESELtrooper] #714222 04/21/06 09:23 PM
Z
zKnightWhoSaysNi Offline
the rim width specs for the 33x9.5 is 6.5" to 8.5", but I think that the 6" rim would work. To find something to compare to, try to find someone who has/had something in the 235r85 series tires and see how those felt on the road. Those are kinda close in size, maybe not quite as tall. (245mm = 9.5")
Obviously it's not a sports car, so don't drive it like one and you should be fine on the street. And off road, don't air down too much and you should be fine with keeping the tire on the rim in side hill situations. Obviously you will sacrifice mud and sand flotation performance with a less wide tire, but I think trail and snow you will still be just great. And you are saving a little weight by going narrower too. I don't think it is a skinny tire, just not really wide like everyone uses to get through mud.
I don't think that the overall stance width difference of 1" (9.5 vs 10.5) is going to make much difference in stability. Maybe 1" wheel spacers to get a little wider track.
Bottom line, I think that if the tire didn't work or wasn't safe, BFG wouldn't make it in that size.
'99 Trooper, 912's
'89 Trooper RS, 2.6
Moderated by  4x4Wire, Dandeman, Mike Bondi
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5931 MB (Peak: 0.6410 MB) Data Comp: Off Server Time: 2026-06-17 01:45:23 UTC
