Page 4 of 4 1 2 3 4
Re: 1991 montero died (3.0 V6) [Re: FrankR] #714372 04/17/06 05:07 AM
Are all head gaskets the same or should I be looking for a certain manufacturer. If everything else looks good the heads will go back on at the end of the week.
Re: 1991 montero died (3.0 V6) #714373 04/17/06 12:06 PM
FrankR Offline
All head gaskets are not the same. I've only used OE, but have heard that the Fel-Pro PermaTorque gasket is also good.
Check the heads to make certain they aren't warped. Pay particular attention to bolt length, head thickness and no-drag clamping range. Use a true bottoming tap to clean the deck threads. Head bolts should be lightly oiled (30W) and torqued to 80 lb-ft. No re-torque is necessary on OE or Fel-Pro PermaTorque gaskets.
I'd suggest reading the 3 threads contained in the following link:
Head Gasket Threads
Frank
Re: 1991 montero died (3.0 V6) [Re: FrankR] #714374 04/19/06 04:35 AM
I have it all covered except for the no drag clamping range, I dont know what that means. Thanks for all the help.
Re: 1991 montero died (3.0 V6) #714375 04/19/06 05:03 AM
FrankR Offline
I see the other link didn't take correctly - let's try it again:
Thread 1
Thread 2
Thread 3
Frank
Page 4 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6031 MB (Peak: 0.6619 MB) Data Comp: Off Server Time: 2026-11-04 13:36:28 UTC
