Page 3 of 3 1 2 3
Re: Headgasket update [Re: Myota] #715008 04/19/06 10:49 PM
Esquire812 Offline
SUGGESTION: quit pumping coolant into your t-body and power steering vaccum assist thingy!
Connect the hoses that were nopes to the places I mentioned and see what happens. Betchya another nickel it runs!
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: Headgasket update [Re: Esquire812] #715009 04/20/06 02:36 AM
Myota Offline OP
IT RUNS!! <img src="/forums/images/graemlins/smile.gif" alt="" />
But very rough. Maybe the timing shouldn't be at 0' <img src="/forums/images/graemlins/ignore.gif" alt="" /> Duoh!
Thanks Darin. I owe you .10 <img src="/forums/images/graemlins/notooth.gif" alt="" />
I'll reset the timing tomorrow and see if that settles things down.
-Chris
'88 EFI Xtracab, 32 x 11.50 Buckshots, AZ bed, Turbo drivetrain.
Re: Headgasket update [Re: Myota] #715010 04/21/06 02:46 AM
Myota Offline OP
Now that it runs I notice that it doesn't go to the perscribed fast idle when started cold. I have checked all the connectors, hoses, etc. yet I can't figure why this is not functioning.
Any thoughts?
Re: Headgasket update [Re: Myota] #715011 04/21/06 04:27 AM
ZUK Offline
Any thoughts?
My 87 22RE lost its fast idle warm-up also after a headgasket replacement....I never could figure it out. I hope someone here has some insight. ZUK
mostly stock
Re: Headgasket update [Re: ZUK] #715012 04/21/06 03:03 PM
Myota Offline OP
Yea. I have been searching for info on here but so far no luck.
The ECU shows no codes have been tripped(WHAT? No code for coolant in the intake!!!! <img src="/forums/images/graemlins/smile.gif" alt="" />) so I don't think a reset is the answer. Not sure why the TPS would need to be adusted as nothing has been moved.
Once it gets warmed up it sort've idles but not smoothly.
So everyone here who has done a headgasket replacement has not had to make any adjustments after all was back together???
Re: Headgasket update [Re: Myota] #715013 04/21/06 06:05 PM
Esquire812 Offline
Pull your Aux. Air Valve from under the intake manifold and carefully remove the front cover (4 screws). Once you get into the inside, clean it up and then reassemble. Dont forget where the coolant lines hook-up and which are the air tubes! <img src="/forums/images/graemlins/wink.gif" alt="" />
Oh, and the light blue sqaure electrical connector (looks like an injector plug) MUST be reconnected at the backside or your cold idle circuit wont work properly.
85' Sillyca 22R-Esq
Re: Headgasket update [Re: Esquire812] #715014 04/21/06 10:20 PM
Myota Offline OP
Cleaned the Aux Air Valve-didn't look that dirty although there was a bit of moisture inside. She now starts without me having to open the trottle any(just the the key) but the 'fast idle' is only 500rpm. Weird huh?
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6270 MB (Peak: 0.7018 MB) Data Comp: Off Server Time: 2026-06-09 21:49:23 UTC
