tire clearance #715553 04/14/06 02:43 AM
mike3318 Offline OP
I have a stock 94 Toyota pick up with 31x10.5x15 tires. The truck is due for some new tires and I was thinking about going with 33's. Would a 2" body lift give me enough clearance? The truck is rust free and damage free so I do not want to do any exterior body alterations.
I have heard that a two-inch body lift should be rather simple because there should be enough slack in everything. A three-inch lift would be slightly more difficult. Does this sound correct?
Re: tire clearance [Re: mike3318] #715554 04/14/06 03:21 AM
lethe Offline
i have a two inch body lift on my 87', i think the only thing that was tight was the hydraulic line for my clutch. a three inch body lift would probably make others things a stretch. with my two inch BL i cleared 33's. we had some at work and it was slow so i threw on the front and rear and no issues. it even tucked up in the rear fenderwell nicely. the only thing the tire came in contact with was my front mud flaps when i turned the wheel. but you dont need those.
87' ext cab toy
Re: tire clearance [Re: lethe] #715555 04/14/06 05:01 AM
Jake97T Offline
I put a 2" BL on a 94 4runner, 87 Toyota truck, only stretch was the battery cable...otherwise it goes on nice and smooth. as far as stuffing the tires real good 32" tires are best in my opinion, but a 33" is not too hard to work with.
Re: tire clearance [Re: mike3318] #715556 04/14/06 05:04 AM
4Crawler Offline
A 1"-2" body lift is usually sufficient:
- http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml#FAQ10
Especially if you stick to say a 33x10.50 on the stock rims.
Re: tire clearance [Re: mike3318] #715557 04/14/06 07:42 PM
SALMONHEAD Offline
The 33x9.50 BFG All Terrains I run help with clearance as well.
84 4RUNNER,22R,HEDMAN,WEBER 32/36,Davis Unified Ignition,33" BFG
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6048 MB (Peak: 0.6695 MB) Data Comp: Off Server Time: 2026-06-25 15:14:59 UTC
