Rookie in the house has a few questions #716139 04/16/06 01:28 PM
KCjeeper Offline OP
Administrator
As some of staff knows I bought a '95 4Runner a couple weeks ago. Spent some time underneath it yesterday and have a few questions and comments.
When I pulled the front 'skid plate/guard' (don't know what you Toy guys call it) I found 2 things lying in it. One is a round piece of thin black plastic that looks like a cover for something. About 2-2.5" in diameter. Where does it go? The other thing I found was a wire not connected. One end goes to the front diff to what looks like a sensor but I could not find a place for the other end to connect to.
What in the world was Toyota thinking when they put that little bitty oil filter up on the side of the motor where even my skinny little arms can't get at it?
The right-side axle has a torn CV boot at the wheel end. Going to have to replace that before too long.
A/C wasn't working and after checking the refrigerant pressure, which was good, I started investigating and found that the compressor belt was missing. Went ahead and replaced all 3 belts and I now have cold A/C....easy fix!
What is the little switch in the center console just south of the transfer-case/tranny levers? Not the rear-glass switch but the other one.
Hate the cup holder so high in the dash.
I don't like the typical rear sag that these trucks have. Do you guys worry about this or just leave it? If it's just a matter of sticking some fresh springs in the rear I'm up for that.
Enough for now.....I'll post some picks later today and probably have more questions.
<edit> BTW, I like the truck! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Randy Halvorsen
98 Explorer XLT
99 F150 4x4
90 BMW 735i
00 BMW 323i
47 CJ-2A
Re: Rookie in the house has a few questions [Re: KCjeeper] #716140 04/16/06 01:47 PM
Pix would be helpful, but I'll take a couple guesses.
2.5" diameter cover - Might be part of the ADD vacuum acutator cover. Wire is probably part of the ADD system, as well.
I get at my V6 oil filter by going in from the bottom/front of the engine -- kinda near the radiator support. One trick I use, is to NOT tighten the filter on super-tight, by hand. As long as it doesn't leak after you change it, it WILL get tighter with heat and use.
CV's are not that difficult to change. There is a 1993 FSM stickied at the top of this forum. You can search there and get the straight dope. When you get your new boot in place, use some silicone spray on the outside every oil change (not WD-40). That will help the CV boot live longer. ( In fact, use it on all the rubber boots / seals / body insulators.)
My guess on the 'little switch south of the shifters' is that it's likely your ECT Power/Normal switch. Pressed IN, it holds the auto tranny in Low and 2nd gear longer before shifting up, letting the engine wind to a higher RPM. I find it aids in around-town driveabiltiy. I ususally keep my O/D Off (switch on the shifter) and the ECT ON , when I'm in town and below 50 mph.
There's lots on here and other boards about rear sag. I think most owners just leave it, if it's not 'too' bad ( 1" or less). It's a pretty easy swap to get some OME coils and restore the ride height. If you want a little more than stock height, get the OME HD coils. Then you can put some Ball Joint spacers on the front -- get about 1.5" lift up there and fit some 33" tires all around.
Incidentally, 33" is about as big as you might want to go, if your stock tire size was P225's. You likely have 4.56 gears and the V6 / auto tranny combo kinda starts dogging around with too tall of a tire.
BTW -- Glad to have ya,, and welcome to the board. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Mike in AR
Re: Rookie in the house has a few questions #716141 04/16/06 06:57 PM
KCjeeper Offline OP
Administrator
Thanks for the info Mike.
Yeah, I have the 3.0l with the auto. It has 31x10.50's on it which makes it even more of a dog from a stop light. Have no idea what gears yet.
Randy Halvorsen
98 Explorer XLT
99 F150 4x4
90 BMW 735i
00 BMW 323i
47 CJ-2A
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5938 MB (Peak: 0.6503 MB) Data Comp: Off Server Time: 2026-06-23 00:48:13 UTC
